Charge 2's battery not lasting
My battery is not holding a charge for more than half to 2/3 of a the day on my Charge 2.  I plan to replace at Christmas but was hoping there was a fix until then.  Anyone?
2 REPLIES 2
Welcome, @Sheafclan. It's great to see you around.
Thanks for the details provided in your post. Battery's life will depend on different factors (how the device is charged, device's age, etc), and Charge 2's battery will last up to 5 days depending on the usage. I recommend you to check this help article: Can I extend my Fitbit device's battery life? for tips on how to improve the battery's life.
Hope this helps!
If my post was helpful, you can vote for it. You can also mark it as Best Answer if it was what you were looking for!
Thanks for your response.  I read through the suggestions, all of which I currently do.  I believe my Fitbit is destined for the garbage.  :(.  It won’t even hold a charge for half the day.  Appreciate your reply.
