10-05-2016
22:14
10:26
10-05-2016
22:14
10:26
New User. Downloaded a fitbit connect for Windows. Have difficulties to complete the setup process.
Turned on the bluebooth. paired with Charge 2. Connected the USB with the laptop. Updated fitbit connect software to the latest version.
It keeps warning Wireless Sync Dongle is disconnected and Plug in a Dongle
I am stuck on this setup page and have tried two laptops and multiple USB plugs. Doesnt work. I have trouble complete the setup process and cannt use the tracker as the screen keeps saying goto fitbit/setup. Very frustrated. there is no manual in the box and there is limited information on how to go pass this "plug in a dongle" error message.
Any idea how to solve this issue?
10-06-2016 00:51
10-06-2016 00:51
If you are running Windows 10 on the PC / laptop you are using then the setup routine will work using the computer's built-in bluetooth rather than needing a fitbit dongle. However, this is only when using the fitbit app from the windows app store.
If you are using something other than windows 10 or are using the downloaded software on Windows 10 rather than the app then you will need a fitbit dongle to complete the setup. This does not come with the Charge 2 but if you have a dongle from a previous fitbit that will work.
If you need a dongle then it's available for purchase from the fitbit online store (see link at the top of the page) or you could contact customer support via this link to see if they can help:
In the meantime, do you gave a compatible mobile device that you could use to complete the setup? The latest list of supported devices can be found at www.fitbit.com/devices
10-05-2016 22:51
10-05-2016 22:51
Welcome to the forums @cecilysue
You can find the Charge 2 owner manual and related articles here - click
What version of Windows are you running and what is the system on your phone?
Best Answer10-05-2016 22:59
10-05-2016 22:59
I am also stuck at the plug in a dongle setup. This is a brand new device and I literally just downloaded the fitbit software for windows. I have checked my bluetooth settings and the laptop sees the device. How do I bypass this step?
10-05-2016 23:00
10-05-2016 23:00
I'm having the same problem with Windows 7 Enterprise
Best Answer10-05-2016 23:08
10-05-2016 23:08
I am currently having better luck going through the setup process on my iphone with its bluetooth connection. Maybe give that a try? Be sure to unpair your tracker from your computer before you try to pair it with your phone.
Best Answer10-06-2016 00:51
10-06-2016 00:51
10-06-2016 04:07
10-06-2016 04:07
Best Answer10-06-2016 04:16
10-06-2016 04:16
@Arabrab are you trying to set it up on a computer or via an app? If it's an app are you sure it's the latest version?
Best Answer10-06-2016 11:09
10-06-2016 11:09
I'm using windows 7.
10-06-2016 11:09
10-06-2016 11:09
K, will have a try. thanks for sharing!
Best Answer10-06-2016 11:15
10-06-2016 11:15
Thanks very much for the advice. It is really helpful! I'm using windows 7. Don't have a dongle and not willing to buy one. I think Fitbit really should have a note to all buyers that they will need to have dongles to connect with some versions of windows.
I'll have a try on setting it up on the phone.
10-06-2016 18:20
10-06-2016 18:20
Best Answer10-06-2016 21:30
10-06-2016 21:30
My setup didnt work on a Samsung S5, didnt work on my laptop but luckily worked on a Samsung S4.
Fortunately after the setup and software update it then eventually was able to sync with the Samsung S5.
Best Answer12-09-2016 05:19
12-09-2016 05:19
What about a Macbook? Will I need to buy a Dongle?
Best Answer12-11-2016 08:21
12-11-2016 08:21
@babkb77b7 Welcome to our Community! If your Mac has integrated bluetooth you can install Fitbit Connect and use your computer's bluetooth to sync your tracker.
Let me know how it goes!
12-11-2016 09:23
12-11-2016 09:23
It does have integrated bluetooth, but can't detect the fitbit.
Best Answer12-13-2016 06:23
12-13-2016 06:23
@babkb77b7 Do you see any error message on the computer? Which software did you install? Could you share a screenshot if you are getting any error?
I look forward to your reply.
12-25-2016 06:32
12-25-2016 06:32
this is freaking rediculous. I've been trying to setup my son's fitbit for an hour now. Merry freaking christmas! First I get the stupid message error about the age( wow, who gives a crap that my 10 year old has a fitbit! God forbit that, so now I have to just lie on the account).
Then, because my son doesn't have a phone, I have to buy a $20 dongle to setup on my PC!!!!!!!!!!!!!!!!!!!!
Un-freaking believable.
12-25-2016 06:38
12-25-2016 06:38
What OS are you running on the PC? If you are running Windows 10 and the PC has bluetooth then fitbit will work with that and you won't need a fitbit dongle.
The age restriction is part of the terms of use and is related to data protection. Note that giving a false age will mean the calorie calculations will not be as accurate.
Best Answer12-25-2016 06:47
12-25-2016 06:47
