08-29-2016 10:52 - last edited on 09-09-2020 10:26 by MatthewFitbit
Why does the Charge 2 not ship with a dongle? Does the Charge 2 not need one or do I use the dongle from another Fitbit device? Or does a dongle have to be purchased separately?
08-29-2016 11:46
08-29-2016 11:46
Hello @evet and @Annabel398 - The new Fitbit devices are not being shipped with dongles, although dongles can be used. They can be synced with any computer that has Bluetooth.
08-29-2016 11:59 - edited 08-29-2016 17:18
@Ozzie65 is right, a lot of computers don't need a dongle in order to sync with Fitbit trackers. The most current version of Fitbit Connect for Mac and the Windows 10 App supports syncing using a computer's native Bluetooth, click here for more information. @evet @Annabel398
I'd also recommend making sure that you have the most current version of either the Windows 10 App or Fitbit Connect installed on your computer. Click here to download the most current version of both.
Additionally, you can double check to see if your mobile device is compatible with syncing Fitbit trackers here.
08-29-2016 11:16
08-29-2016 11:16
I second this question. I was thinking of buying one for a non-smartphone-equipped relative, but he will need a dongle to sync to his computer. I have an Alta dongle which I never use, because my cellphone is practically surgically implanted. Can the Charge 2 use the Alta dongle?
08-29-2016 11:46
08-29-2016 11:46
08-29-2016 13:54
08-29-2016 13:54
08-29-2016 14:02
08-29-2016 16:14
08-29-2016 16:14
Kristina | Ohio
Charge HR, One – Windows 7, iPhone 5
08-29-2016 16:50
08-29-2016 16:50
@Annabel398 wrote:Can the Charge 2 use the Alta dongle?
@Annabel398 yes. Double check to be sure the computer is supported, as Fitbit is moving to Windows 10 and I don't know about the current version of Mac OS X support (because I use my iPhone to sync).
08-29-2016 19:24
08-29-2016 19:24
my PC is 'older' Windows 7 - and I have no interest to update to 10.
No bluetooth.
SO....If I already have a dongel (from my Flex), will this new Charge2 sync to the PC using that?
or wil it only sync with my iPad?
I do not have a smart phone...live in the boonies with no cel service!
08-29-2016 19:26
08-29-2016 19:26
08-29-2016 23:15
08-29-2016 23:15
@NancyP wrote:SO....If I already have a dongel (from my Flex), will this new Charge2 sync to the PC using that?
Yes, the latest Fitbits are backward-compatible with the Bluetooth dongle that shipped with older Fitbits, so if you happen to have one, you can continue using it.
Dominique | Finland
09-07-2016 04:52
09-07-2016 04:52
I have multiple dongles I don't use but when I go to work the secretaries have theirs set up and my tracker synchs with it.
09-07-2016 07:03
09-07-2016 07:03
Call Support - they'll ship you a complimentary dongle.
Got my Charge 2 yesterday - jury's still out on whether it's worth the 3x more than my old $50 Craigslist Charge HR 🐵
Disappointed that with the larger screen there isn't an option in preferences for larger font sizes for sight impaired users. In 'Clock Face' there's a great large font clock face - but doesn't carry over to the exercise stats. :o(
09-13-2016 22:57
09-13-2016 22:57
Can you see the other readouts outside? I can't with the Alta and may switch.
09-14-2016 18:07
09-14-2016 18:07
A USB bluetooth dongle (if your computer does not have bluetooth) is worth hardly nothing these days. Check on eBay...
09-14-2016 18:24 - edited 09-14-2016 18:25
Please help... just received my new Charge 2 today and am excited to use it... but when I try to connect to Fitbit Connect, it is absolutely insisting that I need to use a dongle. It is infuriating that I cannot set this up and begin using it now. I had an older Charge HR but I lost the dongle. It is my understanding that the Charge 2 does not need one. If it does need one, it should have been included in the box. Any ideas please?
Edited to add: I have a new iMac so all software is up to date.
09-14-2016 21:10
09-14-2016 21:10
09-14-2016 21:30
09-14-2016 21:30
09-14-2016 21:31
09-14-2016 21:31
09-17-2016 05:58 - edited 09-17-2016 06:05
@vampyreska You should be able to do a forced sync if you have it connected with the charger cable to the computer. A bit cumbersome but that works for me. But the best solution was to remove my old Charge HR still not emptied of power far away and then to use the Charge HR dongle for syncing the Charge 2. Because before that the dongle would only sync with the not in use fitbit Charge HR 🙂
