08-20-2019
06:32
21:37
EstuardoFitbit
08-20-2019
06:32
21:37
EstuardoFitbit
Just recently my device is showing that I am doing more floors then before. Is anyone else seeing this?
08-21-2019 09:44
08-21-2019 09:44
@Augsept A warm welcome to our Community!
Let me help you with your high floor count on your Charge 2. Your device uses it's altimeter to detect variance in altitude. It will count 1 floor for every 10 ft it detects you climbed. There are situations that may affect the floor count like stormy weather (that has an actual impact on atmospheric pressure), gusts of wind, an AC unit in a closed room or opening a door. I suggest you start by cleaning the back of the device with cotton and rubbing alcohol then use compressed air at a distance to clear the altimeter's opening (check the image for reference). Finally restart it.
Let me know how it goes.
08-22-2019 06:28
08-22-2019 06:28
