10-03-2018
13:06
18:22
10-03-2018
13:06
18:22
Hi,
I have Charge 2 and caller ID issue showing "unknown" for any number but messaged all ok, is existing in my phone too. I have tried all the steps mentioned above but no luck. This all started to happen when I upgraded my Android OS to Android Pie 9. Please fix the issue, it is very frustrating.
10-09-2018 10:27
10-09-2018 10:27
@mera29072018 Sorry to hear that you aren't seeing the caller id for call notifications. Please make sure you are enabling the Fitbit app permissions under Settings of your Android device. You can go to Settings > Apps> Fitbit app > Permissions and make sure you have it toggled on. Also make sure your app is up to date.
Let me know how it goes!
Best Answer10-09-2018 11:16
10-09-2018 11:16
10-12-2018 22:20
10-12-2018 22:20
I'm having the same issues, after upgrading to Andriod Pie. Notifications seem alot more delayed, and phone calls are all showing as 'Unknown'.
All app permissions are set as they should be.
11-13-2018
09:53
08:33
11-13-2018
09:53
08:33
@Crash_Korse It's great to see that you've visited the Fitbit Community! Sorry for the late reply. Thank you for checking the settings. You can both try refreshing the link between your tracker and your phone by going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
Best Answer11-13-2018 23:53
11-13-2018 23:53
Hello,
I would advise you to check if the language you have on your phone is supported by fitbit. In my case, where the language is greek, I always get an unknown caller id for all phone book entries that have greek characters.
Cheers
12-05-2018
08:38
08:32
12-05-2018
08:38
08:32
@akalion A warm welcome to our Community! Thank you so much for participating in the forums and sorry for the late reply. I appreciate that you added this bit of information as it is important and may help other members in the same situation.
I'll be around!
07-07-2019 13:56
07-07-2019 13:56
I have tried everything suggested and it still comes up unknown when a contact calls me
11-18-2019 04:24
11-18-2019 04:24
I just upgraded my phone (pixel 3a with android 10) and I can't get caller to show on my charge2. I also tried the workarounds on this thread but no luck so far.
