Charge 2 stopped holding charge
Hi
For last 2 days my charge 2 is charging up fine but not holding its charge. After 12 hours I need to charge again. Before this it lasted around 5 days. I did an update a few days ago on software will this be the reason ? Can it be fixed ?
58 REPLIES 58
How bizarre... Mines started doing exactly the same too around 2 days ago as well 🤷🏼‍:female_sign:
Mine stopped working a few weeks ago.  Wouldn’t take a charge.  So I ordered a new charger and now it’s working but the charge only lasts two days!  Did anyone get a response from someone from Fitbit?
I called and spoke to help desk as now not syncing either. Tried multiple fixes but no joy. Want me to fork out for a new Fitbit when it's their fault mine isn't working !
Did you apply the new software update ? that's when mine stopped working.
At the end of June mine started vibrating while I was wearing it.  No messages coming in, not alarms, etc.  I could not stop the vibration and unit died.  From that point on it would not hold a charge.  The unit is 1.5 years old.  It is a waste of money.
Mine has not been holding it's charge for about a three weeks now, was for 48/24 hrs then down to 12 hrs, then this week just 5 hrs and then yesterday and today for only 2 hrs at a time. Came in from doing exercise today and the charge only lasted less than 3 hrs I synced then was about to put on charge as almost dead and it started flashing the message "www.fitbit.com/setup" and now won't charge and won't turn off and has been flashing this message for the last 3hrs!
I experienced the exact same problem just a few days ago. After the software update it the steps totals didn't match after syncing and I started noticing other discrepancies. Then suddenly the battery didn't hold a charge. The company needs to take a look at this.
Mine automatically updates I think & it says I’m up to date on updates so I reckon it’s a problem with this if we’re all experiencing the same thing 😡 I emailed them yesterday tea time so waiting on a reply. Will post when I hear anything
Hi all, same here! For the last 2 days my Charge 2 doesn't charge- the moment i plug it in it says 100%, i leave it on the charger for an hour and still it doesn't hold its charge more than 2-3 hours, doesn't track any exercise, sleep, heart rate. It also started vibrating often without any reason and the green lights are extremely bright suddenly.  Finally,  when I woke up this morning, it was of course dead, then it started flashing the message "www.fitbit.com/setup" and now won't charge and won't turn off and this message is all I see! Have this for almost 1 year, do these things die so early and without warning? Did anyone find a solution? Good luck all
Hi Dollybee
I phoned yesterday. Spent 45 mins with help team trying to fix but could not. Maybe report your too.More reports they might take problem seriously!
No solution apart from 25% discount on a new one ! which I'm not having. Its Fitbit problem so why should I buy a new one !
I couldn't find contact information on the website. They need to know there are problems. Could you post?
Dolores
My Charge 2, also stopped holding a charge. Now it only stays on for 2-3 minutes. Side note: it says my software is up to date. Yes I’ve cleaned the contacts on watch and charger.
0800 0698505 this is UK free phone number.
Yes I’ve emailed them as well, still waiting a response!
Sent from Tracey's iPhone
I’ve just been told in an online chat that the warranty is 2 years. So if anyone is less than 2 years you should get a new one! They also said I would get a 45% discount but in the email link it’s only 25%’
Pollykettle read the reviews on Google play store. Hundreds of people complaining about glitch in new software update. They will need to roll out a patch. Give it time and fingers crossed we will be up and running soon. Customer Services or Fitbit should be issuing a statement to all their customers.
Awesome! Thank you so much!!
Sent from my iPhone
My charge 2 fitbit will charge but the charge will only last for about 5-8 hours where it use to hold the charge for about 5 days or more.  The display on the back is orange/red.  I cleaned the contact area with cotton and rubbing alcohol and it still doesn't work...any suggestions on what to do?
