03-10-2019
13:32
17:14
03-10-2019
13:32
17:14
I've had a charge 2 and which syncs with my Samsung Galaxy 8s for about a year and a half, no problems until January 1st, 2019 when it stopped syncing. I've restarted both devices. Removed and reconnected the Bluetooth connections. When I try to force a sync, it just tells me that it is scheduled and will occur soon, but gives me no manual override option to force the sync. Any ideas? The help topics don't seem to cover this issue.
03-11-2019 06:48
03-11-2019 06:48
@danrstevens It's great to see that you've visited the Fitbit Community! Sorry to hear that your tracker isn't syncing and thank you for troubleshooting this issue. You can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on. You can find additional suggestions here.
Also please be aware that Android users are having issues syncing with Android 9 (Pie), you can check this thread to keep up to date with this.
Let me know how it goes.
Best Answer03-11-2019 10:55
03-11-2019 10:55
Best Answer03-11-2019 11:29
03-11-2019 11:29
Best Answer03-11-2019 16:47
03-11-2019 16:47
