06-11-2018 17:56 - last edited on 09-08-2020 18:54 by MatthewFitbit
What can I do if the strap will not stay attached? This is after about a year of use. Have already tried to tighten the screw in the strap. This did not help. I can see no visible damage or reason for it not to stay clicked in.
06-12-2018 04:49 - edited 06-12-2018 04:49
Welcome to the Fitbit Community @SunsetRunner! Thanks for trying to tighten the screw in the strap, nice way to go!
Would you mind sharing a picture of how your band looks like?
Personally, I haven't had any issues with the band on my Charge 2 and I have been wearing it since 2016 and it comes off only when I press the clasp inside the band to release it.
The only thing I want to add is that you can try pulling the metal tab to the outside so it helps secure the wristband. Also, check the small screws holding the latch onto the tracker to ensure they haven't come loose. I know you have done something like this, but you can use a very small jewelers screwdriver to tighten the screws to see if that corrects the problem.
If your wristband is broken, please reach out to our team at https://contact.fitbit.com so that they can help you with your available replacement options based on the Warranty Policies. If you go for this, please provide a picture of your band.
If there any questions present, please let me know and I'll be glad to help.
06-12-2018 06:15
06-12-2018 06:15
Hi. Thanks for your reply. Since there is nothing else I can do at home I have reached out regarding possible strap replacement. I am within a month past my warranty. Thanks for the links and tip about including a photo, which I have done in my email.
06-26-2020 20:22
06-26-2020 20:22
Same problem here. Both strap ends just lift off the unit. They won't catch the tabs on the module - may be worn or something. Neither strap I have will stay on. Just checked with the online chat and it's out of warranty and they don't repair, so the solution proposed was a link to the store to buy a new one...very helpful.
I guess I'll try to glue it or something.
