11-30-2016
20:06
10:26
11-30-2016
20:06
10:26
Just got the Charge 2 yesterday. I'm at 9999 steps for the day and have continued walking around, but the count does not roll over to 10k. I'm able to sync to my phone, and the device seems to work normally, but it's stopped incrementing the step counter.
Please help, I'd hate to return this and go back to an older device 😞
11-30-2016 20:15
11-30-2016 20:15
@SunsetRunner, I would suggest you try restarting your tracker first to see if that corrects the problem. Many user find it most helpful to restart it 3 or 4 times in a row to make sure the tracker starts clean.
If you are not familiar with the restart procedures, check out this help page https://help.fitbit.com/articles/en_US/Help_article/1186/
11-30-2016 20:15
11-30-2016 20:15
12-01-2016 06:11
12-01-2016 06:11
@SunsetRunner Welcome to our Community! Did you try restarting your tracker like @USAF-Larry suggested? This is odd. Lately I have been able to reach my goal (I am a couch potato) so I have seen 12k to 14k without a problem, what I am trying to say is that this is not common and there should not be any issue preventing your tracker from showing more than 9,999 steps.
Let me know how it goes!
12-01-2016 09:21
12-01-2016 09:21
Hi Larry,
Thanks for the advice. Restarting my phone and the tracker seemed to unlock it; I'm not sure exactly which did it, but it did start tracking steps again. I think the 9999 was a red herring, it could've gotten stuck at any other step count.
I'm hoping this isn't a recurring issue though, as it would stink to have to check my tracker every once in awhile and then reset it every day or whatever.
12-01-2016 09:40
12-01-2016 09:40
Glad it corrected it, @SunsetRunner! I don't think it will be a recurring problem. Keep on stepping!
01-03-2017 21:09
01-03-2017 21:09
I had the same issue except it was stuck at 9998 steps. Resetting the tracker solved the issue. Thanks for the posts.
04-25-2017 13:46
04-25-2017 13:46
So random - mine was stuck at 9999 steps, so I googled it and found this article. The restarting my phone/tracker didn't do anything, but then I entered "Run" workout mode and it started working again.
Really weird. May be some kind of bug.
11-20-2017 12:45
11-20-2017 12:45
Great tip, this worked for me too. Thank you!
10-12-2018 17:38
10-12-2018 17:38
NOT solved. Tried restarting several times. No luck. This seems like a systemic issues. Guess I'll go with a Garmin when the Charge 2 craps out.
11-13-2018 09:29
11-13-2018 09:29
@wxing Welcome to the Fitbit Community! I hope you're doing well! Sorry to hear that your tracker is stuck and for the late reply. Try setting up the device as a new one on your account (tap the account icon at the top right corner, then tap the trashcan icon to remove it).
05-02-2019 17:22
05-02-2019 17:22
Thanks I had tried the restart and then found your tip re Run worked and FitBit is now counting again
05-18-2019 11:52
05-18-2019 11:52
@Cliveofindia A warm welcome to our Community!
Thank you for your reply and for following my suggestions. Also appreciated that you took the time to confirm that the suggestions worked for you as this may help other members in the same situation.
I'll be around.
02-23-2021 17:01 - edited 02-23-2021 17:02
I’ve had my charge4 for about two weeks and it just did the exact same thing. Stuck on 9999 as I was running around the house shaking arm etc. so I lost about 100 steps then restarted it and it works again. I hope this is not a recurring problem!
02-25-2021 10:04
02-25-2021 10:04
@belagrace It's great to see that you've visited the Fitbit Community!
Thank you for sharing your experience and for confirming that the restart helped you solve the issue. If the issue persists please know that our Support team is available to help you in any way possible.
I'll be around.
08-11-2022 18:09
08-11-2022 18:09
Thanks! This workaround worked for me too. I have a versa 2.
