06-05-2017
18:00
09:49
06-05-2017
18:00
09:49
My charge 2 is going hay wire... turning notifications on and off all on it own.
02-15-2019 15:50
02-15-2019 15:50
Best Answer02-19-2019 19:23
02-19-2019 19:23
Best Answer02-20-2019 06:28
02-20-2019 06:28
Best Answer02-21-2019 19:09
02-21-2019 19:09
Mine does the same thing,
When I upgraded the IOS and synced it is when the problem started happening.
Best Answer03-03-2019 01:42
03-03-2019 01:42
I have restarted as suggested
The Charge 2 is fully charged
The full battery screen ateyed visible when the unit was removed from the charger.
When I pressed the button the message "Woo I feel energized" appeared and then it went into the loop "Notifications on then Off then on etc.
Best Answer03-03-2019 05:37 - edited 03-03-2019 05:39
@Norman.Kennedy what did support get back to you with when you contacted them?
If it is a hardware problem, the answer is to contact Fitbit.
Best Answer03-03-2019 05:46
03-03-2019 05:46
I wrote a a number of responses in response to a support request in chat.
There was no response, I gave up after waiting for nearly 30 minutes.
Best Answer03-03-2019 17:26
03-03-2019 17:26
Best Answer03-07-2019 05:37 - edited 03-07-2019 05:41
@Norman.Kennedy @Justrite53 thank you for your updates. Since the issue persist I have created tickets with Support so they can further assist you as @Rich_Laue said they can help with hardware issues.
Keep me posted.
Best Answer05-14-2019 11:23
05-14-2019 11:23
Is there any new on that topic?
Best Answer05-14-2019 15:33
05-14-2019 15:33
Thank you
I went through a very good process with support. I sent videos and screen shots.
The ens end result was an offer to replace my charge2 with a new unit for free or 50% off a charge3 which offer I accepted to take the charge3.
By by the way the charge3 is a big improvement and worth the upgrade
Norman
Best Answer05-14-2019 15:45
05-14-2019 15:45
Thank you
The end result was an offer to replace my charge2 with a new unit for free or 50% off a charge3 which offer I accepted to take the charge3.
Norman
Best Answer05-15-2019 14:01
05-15-2019 14:01
Best Answer06-04-2019 07:23
06-04-2019 07:23
Well mine started doing this today, google searched and found mine's not a lone case. Many people have reported the same issue for the past 2 years however i do not see a solution from fitbit yet..strange. Charge hr had band bubbling issue and i thought charge 2 is a killer but stuck in the same situation again!
Best Answer06-06-2019 04:15
06-06-2019 04:15
Yes I did still is not working
Best Answer06-06-2019 04:19
06-06-2019 04:19
What should do now
06-06-2019 06:21
06-06-2019 06:21
Best Answer06-06-2019 10:30
06-06-2019 10:30
15:38
06:27
GraceGFitbit
06-06-2019
15:38
06:27
GraceGFitbit
Hi,
I had a lot of help from Fitbit supoport but in the end they could not fix
it and offered a replacement or a discount on a Charge3 which I took.
Regards
Moderator edit: Removed personal information.
Best Answer06-22-2019 07:05
06-22-2019 07:05
Mine is constantly switching notifications on and off and buzzing, which drains the battery very quickly. I tried all the resets rx here with no results. Kind of tired of FBs failing...I have had three Flex, Flex 2 and now Charge 2 (4 total) in a five year period that failed. That’s over $500 just to track steps. I think I could of bought an excellent pedometer three times over. That is an unacceptable track record for product performance and quality.
