06-05-2017
18:00
09:49
06-05-2017
18:00
09:49
My charge 2 is going hay wire... turning notifications on and off all on it own.
06-29-2019
19:06
20:43
DavideFitbit
06-29-2019
19:06
20:43
DavideFitbit
I've not had any problems,sofar, with my Charge 3.
The Charge 2 failed like yours but I was offerred a no costreplacement.
Regards
Moderator edit: removed personal info
Best Answer07-14-2019 08:59
07-14-2019 08:59
This has happened to me too over and over again and the resets don’t work..what it the real problem? I don’t want to hear another person saying “ we’ll buy a new one”..This is unacceptable! We need a fix to this random notifications on off flashing issue...it makes this unit worthless!
Would like a solution please fit bit!
07-14-2019 09:27
07-14-2019 09:27
I call bull sh...t Rich,... quit lying to people. Due to your dishonesty I will never buy another fit bit device again! Unacceptable!
Best Answer07-14-2019 09:28 - edited 07-14-2019 09:31
The problem is that if a user accidentally holds on the button to long notifications will be turned off or on.
The button could be held in to long while navigating the screens or getting caught on something, let's say a boxer when the glove turns off the exercises recording.
The easy fix is to disable this hold in button from all but the notification screen when this screen has been added.
So @4l your going to base your whole relation with Fitbit based on what a fellow Fitbit user has posted? I have explained why the resets don't work.
Best Answer07-14-2019 09:51
07-14-2019 09:51
Its time to take this issue to Twitter and Facebook letting others know about how fit bit won’t fix all these issues but ask that you buy another device..... unacceptable
Best Answer07-14-2019 11:50
07-14-2019 11:50
Did Fitbit really ask you to by another device?
Also is having a conversation between Fitbit users the best way to bring this up to Fitbit?
Best Answer07-14-2019 12:07
07-14-2019 12:07
Best Answer07-15-2019 07:37
07-15-2019 07:37
I have a possible fix that will need the developers to implement.
They did make changes for this and other Charge 2 issues with the Charge 3.
Best Answer07-15-2019 18:22
07-15-2019 18:22
Best Answer07-17-2019 09:05
07-17-2019 09:05
This is happening to me too! What is the fix????
@Joylyn126 wrote:This has been happening to me as well. Is there a fix for this?
Best Answer07-17-2019 09:12
07-17-2019 09:12
If the button was held too long why is that a problem? There should be a way to reset successfully...but that doesn’t work either..you have to admit that’s lame that is you press a button too long it makes the device do haywire and become unusable and a worthless piece of $150.00 plus garbage??? It’s time to buy an Apple or Garmin! And by the way a 25% discount is unacceptable.
@Rich_Laue wrote:The normal reason for notifications on the Charge 2 to get turned off is simply because of some reason the button got held in to long
Best Answer09-22-2019 18:17
09-22-2019 18:17
It’s becoming obvious this is happening ON PURPOSE! It’s happening to too many people at the same time... If there was a way to disable “updates” I would for this specific reason. I’m going to try to start a viral campaign/conversation to force an investigation... Nothing worst than being SCAMMED! 👎🏾
09-22-2019 18:21
09-22-2019 18:21
Best Answer09-23-2019 04:50
09-23-2019 04:50
Best Answer09-23-2019 06:08
09-23-2019 06:08
The way to turn notifications on or off is by holding in the button.
I very much doubt that the user is holding in the button on purpose then complaining that notifications have been turned off, when they them self i. Purpose turned notifications off.
I suspect that the user is accidentally holding in the button.
Best Answer09-23-2019 12:51
09-23-2019 12:51
Mr. Rich,
What will it take for you to believe all the users who will tell you that they are not holding the button. You can take the device off, and put in front of you on the table, and it keeps buzzing On/Off. You're sticking up a company who would rather ask you to buy another device than solve a problem. I firmly believe their staff has clear instructions to offer a new purchase if they can't solve an issue (because they still make more money on the purchase than spending resources on solving a bug).
09-23-2019 16:33
09-23-2019 16:33
Well you're the first to mention that this is happening while on a table.
This thread title is about notifications randomly turning on/off.
Having a tracker that sits there constantly buzzing, switching notifications on/off and jumping around screens is not a random ccurrence but a hardware issue that only Fitbit support will be able to address.
A simple random on/off of notifications is not what you are describing but is what the title says is happening.
Best Answer09-23-2019 17:07
09-23-2019 17:07
Best Answer09-23-2019 17:14
09-23-2019 17:14
Best Answer09-23-2019 18:18
09-23-2019 18:18
To clarify any misunderstandings, i am not an employee of Fitbit.
If I'm unable to figure out what a person is asking, based on a lack of info, i will assume that their question is based on the title/subject of the thread and not an hijacked tangent.
