10-07-2016
16:59
10:26
10-07-2016
16:59
10:26
10-07-2016 17:37 - edited 10-07-2016 17:38
Text and call notifications require pairing @evance1024
On your 6s go to settings, scroll way down to applications, touch fitbit then notifications, make sure notifications are "on". Go to bluetooth and "forget this device" (circle i for dialog) any trackers connected. Return to the home screen and hold any app icon until they all wiggle. "x" (delete) the fitbit App. Use the Safari browser to go to fitbit.com/setup and download the App, follow the guidance for "add a new device with an existing account." Come back and let us know that when you got to the 4 digit code pairing the first time it was a success so we can pass this advice forward 🙂
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
WmChapman | TX
10-07-2016 19:00
10-07-2016 19:00
10-21-2016 14:07
10-21-2016 14:07
I followed your instructions and received the pairing 4 digit number typed it in......now to see when I get a call if it shows up.......thank you for your assistance.
11-30-2016 19:10
11-30-2016 19:10
What about for a Note 3. Text and call notifications not showing on my Charge 2?
Best Answer12-08-2016 15:34
12-08-2016 15:34
Mine is paired just fine, but none of the text or calendar notifications come through. I'm sure I just need to turn the feature on somewhere, but I can't find where.
I have Motorola Droid Turbo, Message + and Jorte Calendar
Best Answer12-08-2016 17:25
12-08-2016 17:25
Problem is today alone I had to do it 4 times and called Fitbit 2 times.
12-14-2016 21:52
12-14-2016 21:52
Tried to follow these steps but I did not get a new 4 digit code pin. Any suggestions on how to fix this problem?
12-14-2016 22:30
12-14-2016 22:30
I had to plug Fitbit into charger and into my computer.
12-15-2016 06:48
12-15-2016 06:48
Why into the computer ?
Best Answer12-15-2016 06:50
12-15-2016 06:50
The steps to restart it say to have it plugged in (and I don't have a wall charger, only my computer) and then push the push until it restarts. I did it 4 times. I finally got all the settings set correctly and mine now work.
12-17-2016 08:47
12-17-2016 08:47
Hey guys! I hope you are all having a great day!
@evance1024 and @SunsetRunner, I appreciate you are letting us know that the steps that my friend @wmchapman posted above, worked for you. 😉
@KrisLDavis, is it the Samsung Galaxy Note 3 Neo, the phone you have? 'Cause that one is a compatible device so it should work with call and text notifications. So I suggest you to review this post and follow the instructions there if you are not receiving them on your phone.
@Niccirn1, so Fitbit Support advice you to perform a restart? And in order to do that, you have to plug your tracker as @aswasson mentioned. Besides that, you can follow the instructions that I posted above. If you are having the same issue, I suggest you the same @Vihaan.
Let me know how it goes!
Best Answer12-17-2016 10:38
12-17-2016 10:38
Best Answer12-17-2016 12:02
12-17-2016 12:02
I did everything that is supposed to have been done to restart my charge 2 and I still can't get it to work right....I'm seriously thinking about sending it back, I wanted to factory reset it but seems that is impossible 😞
12-17-2016 12:11
12-17-2016 12:11
I have a Note 5 and have done all of the steps and still cannot get the notifications to come thru. This is very frustrating. How can I get a replacement? Too much money was spent to not have the one feature I wanted most in this device. #Ridiculous
12-17-2016 17:25
12-17-2016 17:25
Same problem. Have reloaded app several times and put into bluetooth several times. Still will not get txt and phone alerts
12-17-2016 17:54
12-17-2016 17:54
I'm not sure what steps have been taken @Tisdale, @KD62, and @HalfMary.
In the app is notifications set I to the correct apps?
Swiping down on the status bar, do you see an entry that says Fitbit notifications are running?
In the phones sound settings, hold finger on the sound icon in the status bar for 2 seconds, check that show on lock screen is enabled,
Restart the Charge
Power off the phone, start up phone
On the phones BT setting make sure the Charge is showing as connected, the app should have done this.. If it isn't then notifications may not work.
Under the fitbit app - account - Charge 2 - notifications in the top right corner click the 3 dots then send test message.
12-21-2016 06:55
12-21-2016 06:55
Hi,
Have you solved this problem by any chance? I have a note 3 also and I cannot receive any notifications at all.
12-21-2016 08:09
12-21-2016 08:09
Best Answer12-21-2016 10:49
12-21-2016 10:49
@powerapple The following steps should help:
1. If you use another Bluetooth device on your Note 3, it may be causing interference that prevents notifications from appearing on your Charge 2. Click here for more details.
2. To help improve the delivery, go to Notifications and make sure Enable Notification Widget is on.
3. Make sure that "Always Connected" is turned on in the Fitbit App. This improves the Bluetooth connection between your Charge 2 and Android phone.
4. Make sure that you are using the latest firmware version on your Charge 2, version 22.48.14. Click here for instructions on how to update.
After steps 1-4, I'd then recommend the troubleshooting section in this help article. This should help, but please keep me posted.
