10-07-2016
16:59
10:26
10-07-2016
16:59
10:26
09-28-2017 18:57
09-28-2017 18:57
09-29-2017 00:28
09-29-2017 00:28
I've followed the instructions but I don't get the option to set up with existing account, just to log in. So no code!
Best Answer09-29-2017 20:09 - edited 09-29-2017 20:12
@debbietblue have you checked the app settings, the phone settings, the DND mode on the tracker irself, does the Charge 2 show up as comnected in the phones Bluetopth, if android (it sure would be nice when mentionning a phone problem to also mention the phone) do you get notifications on the lock screen, is your phone on thr compatible list.
@Bumbleb33 this thread is about notifacations, what is it that you want to do, and what device is neing used to do this? Normally a user needs to be logged into their Fitbit account to do something with their existing account.
10-02-2017 06:42
10-02-2017 06:42
I am having the exact same problem i have tried resting fitbit. Disconnecting it and going through setup process as stated in comments on this post. I recieve phone calls notifications but not messages even tho i have them set to give me notifications i have tried everything i possibly can and it will not fix 😕 im not happy at all iv only had this fitbit for 1 month and it was a birthday present
Best Answer10-03-2017 12:13
10-03-2017 12:13
I am not longer getting notifications on my Charge 2. I have followed the instructions re forgetting my device and deleting the app off my phone. Went to fitbit/setup which sent me to the app store to download app. Added new device, got the four digit code... Did this twice, still not receiving notifications.
Best Answer10-03-2017 13:09
10-03-2017 13:09
10-03-2017 15:37
10-03-2017 15:37
Best Answer10-03-2017 16:28
10-03-2017 16:28
I have tried all of this and am still not getting vibrations for notifications. I am getting a vibration for alarms, but not texts/calls or reaching my goal. I have N iPhone 7. Any ideas?
Best Answer10-03-2017 17:59
10-03-2017 17:59
Severa question for Fit Bit
How long is this outage of incomming Text/notifications not working been known to your organization?
How long/ when is the proposed patch going to be available?
Is this issue similar to the software flaw that effected sleep tracking that occurred in September of this year. That was the issue where we the customers were openly and consistently lied to by your organization.
Why would I ever consider buying / recommending any product from your Company based on your history of incompetence and lack of customer service?
10-04-2017 10:25
10-04-2017 10:25
What are the steps for a Samsung S5 Neo?
Best Answer10-05-2017 21:21
10-05-2017 21:21
Excellent!
It worked and very easy to restart It!
Thanks!
Best Answer10-09-2017 13:56 - edited 10-09-2017 14:02
My fitbit Charge 2 is not showing me the texts or calls on my device. I have tried restarting twice, I also tired unpairing then repairing the device to my phone. I also tried reinstalling the app. Nothing seems to be working.
UPDATE: learned that my 5 year old pushed the side button on my fitbit... didn't check that one... good call fitbit community!
Best Answer10-09-2017 13:59
10-09-2017 13:59
OMG you are a genius. this might have just solved my issue....
Best Answer10-09-2017 16:58
10-09-2017 16:58
Followed al these directions n still doesn't not receive texts & incoming call display anymore....
Best Answer10-11-2017 13:36
10-11-2017 13:36
I did as @Lotharlux said....I saw that I had turned notifications off on the Fitbit itself but had no idea how I did it - I just held the button on for a few seconds until it displayed "Notifications On"
Thanks!
Best Answer10-31-2017 10:53
10-31-2017 10:53
I am having the same problem too, calls and texts not displaying on my fitbit Charge 2. I want to try suggested solution but I am worried I will loose my weekly progress, as I am competing with several other people each week. Do you know if I will lose my progress?
Best Answer10-31-2017 11:06
10-31-2017 11:06
My problem was an easy fix. Hold down the button for a second or two and a message appeared that turned on the notifications-didn’t effect anything but my notifications came back
Best Answer10-31-2017 15:21
10-31-2017 15:21
Best Answer10-31-2017 17:24
10-31-2017 17:24
Best Answer10-31-2017 21:37
10-31-2017 21:37
