10-03-2016 15:44
10-03-2016 15:44
09-11-2017 12:50
09-11-2017 12:50
Best Answer10-17-2017 19:02
10-17-2017 19:02
This option doesn't exist on my phone. I get the exercise shortcut but no plus sign.
@USAF-Larry wrote:@SunsetRunner, do you already have 7 exercises in the Exercise Shortcuts? If so, you must delete one before you can add another - 7 is the maximum number of shortcuts you can have.
If you do not have 7 shortcuts, you should see a line at the bottom of the Exercise Shortcuts that you can click to add one or more, such as in this screenshot:
Best Answer01-07-2018 21:16
01-07-2018 21:16
Hey Derrick,
I see the exercise shortcuts, for me they are run, weights, treadmill, workout, elliptical, bike, interval workout.
- there is no walk option for me on the charge 2, any suggestions?
01-08-2018 00:20
01-08-2018 00:20
@Fit42018 you have your Charge 2 maxed out with 7 workouts, you will need to remove one before another one c k be added..
01-31-2018 06:35
01-31-2018 06:35
I tried your fix, removed all my exercise options and there is still no “walk” option. Any other ideas?
Best Answer03-16-2018 09:28
03-16-2018 09:28
Having problems adding "Walk" to my 7 workouts on my charge 2. What do you mean "drag handles to reorder". And nothing happens when I try and swipe left on my watch to delete workout to add the "walk"
Best Answer03-16-2018 09:38
03-16-2018 09:38
GOT IT! Thanks
If your Fitbit device has an Exercise menu or app, you can configure the exercises available on your device to show only the exercises that interest you. If a specific exercise isn’t available, we recommend choosing Workout as your exercise type.
To change or re-order exercises on your Fitbit device, choose a section below:
FITBIT APP FOR IOS
From the Fitbit app dashboard, tap the Account icon (User-added image) > your device image.
Tap Exercise Shortcuts.
To add a new shortcut, tap Exercise Shortcut and select an exercise.
To remove a shortcut, swipe left on an exercise name, then tap Delete.
04-03-2018 11:24
04-03-2018 11:24
@slanciawrote:GOT IT! Thanks
FITBIT APP FOR IOS
Got it!! THANK YOU!! 🙂
Best Answer07-10-2018 13:12
07-10-2018 13:12
Can you explain how you added walk to your charge? Apparently, I am tech challenged! Thanks!
Best Answer07-11-2018 06:23
07-11-2018 06:23
@LHE I'm not sure what phone you have, but the procedure is the same for them all, and explained in the post above your post.
The multisport mode is also explained in your user manual and in fitbits help docs.
How do I use exercise apps and modes on my Fitbit device?
07-11-2018 10:01
07-11-2018 10:01
Finally figured it out, thanks for the help.
07-11-2018 18:13
07-11-2018 18:13
Best Answer07-11-2018 19:01
05-21-2019 11:04
05-21-2019 11:04
Hiya,
I can't see that this link directs you to instructions now? Is it still possible to track a walk with Gps?
Many thanks
Best Answer05-21-2019 11:10
05-21-2019 11:10
Sorry @marniec09 I'm not sure which link your referring to, or which model Fitbit you might have.
The ionic has built in GPS ans most of the other trackers will connect to and use the phone's GPS, so the answer most likely is yes you can use GPS.
We have a few help docs on this subject.
