03-01-2020
04:00
10:14
03-01-2020
04:00
10:14
I updated the Fitbit app on my yesterday 2/29. As of yesterday my Fitbit would just turn off randomly, I would press the side button and nothing would happen. A few hours later it would turn back on, showing a time 3 hours earlier than it was. Happened multiple times since the update. I tried charging my device last night, shows it was charging but didn’t. Any ideas?
03-02-2020
08:38
06:11
03-02-2020
08:38
06:11
@Kirrin Welcome! Thanks for being part of our Community!
Let me help you with your Charge 2 turning off and not charging and thank you for troubleshooting this issue. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves.
Let me know how it goes.
03-04-2020 13:07
03-04-2020 13:07
Thanks I have tried 99% of this. How do I restart my device? That I’m not sure I’ve done correctly.
03-09-2020 08:09
03-09-2020 08:09
@Kirrin thank you for the update and sorry for the delay in mine.
You can find the restart instructions on my previous post. Just click on where it says "restart your device". See if this helps you resolve the issue.
Keep me posted.
