Charge 2 will not hold a charge
My Fitbit will not hold a charge.  After charging, battery life is less than an hour.  I have had it for about 18 months.  Is there a way to fix this? Or is it time for a new one?
1 REPLY 1
@Rodxmc Welcome to the Fitbit Community! I hope you're doing well! Sorry to hear that your tracker isn't holding its charge. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves.
Let me know how it goes!
Alvaro | Community Moderator
