10-15-2022
13:22
15:44
AndreaFitbit
10-15-2022
13:22
15:44
AndreaFitbit
Charge 2 won’t connect to the phone
10-15-2022 13:28
10-15-2022 13:28
Solved
Best Answer10-17-2022 15:51
10-17-2022 15:51
Welcome to the Fitbit Community, @Costyy. I'm sorry to hear your Charge 2 didn't connect to the phone and I'm glad to hear that you were able to connect it.
For future reference you can check: Why won't my Fitbit device sync?
Keep on visiting the forums.
Best Answer10-21-2022 02:31
10-21-2022 02:31
Select Restart, then OK.
Click the Action Center icon in the bottom right corner of the screen.
Tap on the All Settings tile after that.
Then go to Devices.
Select Bluetooth from the left-hand column and ensure the Bluetooth switch is in the On position to the right.
Regards,
Will
10-21-2022 08:23
10-21-2022 08:23
Best Answer10-21-2022 10:04
10-21-2022 10:04
