05-02-2018
20:43
18:54
05-02-2018
20:43
18:54
Ever since I got my fitbit Charge 2, text messages have never displayed. I can see that I have a text message, but not the message itself. I never thought anything of it because I thought that was normal. Today, I found out that my friend with the same kind of fitbit is able to read her text messages. I don't know what to do to fix it. All of my notifications and permissions are enabled to receive them. I also just upgraded my phone from the Samsung S7 to the S9+ and still doesn't work. Thanks for your help.
05-05-2018 08:00 - edited 05-05-2018 08:29
Welcome to the Forums @aprilb123!
Thanks for sharing your inquiry, let me help you out. You mentioned that now you're using the Galaxy S9, I've checked on the compatible devices list and is not listed as a compatible device, however you can attempt following the instructions below:
I also moved you post to the Charge 2 board since it's more related to the Charge 2 board since it's more related to your inquiry.
Let me know how it goes!
05-05-2018 08:03
05-05-2018 08:03
Hi thank you. My phone does work with fitbit. It was a setting in my text messages that I had turned off. Once I turned on message preview, it worked.
05-23-2018 06:50
05-23-2018 06:50
Hi there @aprilb123! Sorry for the delayed response!
I'm glad to hear that you're back on track. Have you checked our Discussions board? There you can share your story, find some fitness tips, recipes and more! Give it a look!
See you around!
05-31-2018 08:23
05-31-2018 08:23
Where and what notification did you change? I've looked both in the app and online. I can't find where I've got something turned off. I only see new message alert, it doesn't display the text.
05-31-2018 08:32
05-31-2018 08:32
Hi...Here are the steps I took to turn on the ability to preview messages. I originally had it off so that when a text message came in, it would not display the actual message on my Samsung phone, for privacy, but doing that prevented messages from displaying on my Fitbit and smart watch.
1. Open your text messages
2. Tap 3 dots menu button at top right select Settings
3. Tap Notifications
4. Tap More Settings in App
5. Turn on Preview Message
Hope that helps! That's all I did and now I can read text messages on my Fitbit.
05-31-2018 08:56
05-31-2018 08:56
IT WAS A PHONE SETTING!!! I'm sorry, in all these comments I thought it was a fitbit setting. Thanks for your help!!!
05-31-2018 09:03
05-31-2018 09:03
You're welcome! Took a while, but finally a Fitbit customer rep told me to do that...so easy!
09-07-2018 11:06
09-07-2018 11:06
Thank you so much for your answer! Your answer was way more helpful than anything from Fitbit.
09-07-2018 11:22
09-07-2018 11:22
09-07-2018 11:24
09-07-2018 11:24
You're welcome! Glad I could help!
07-18-2019 08:02
07-18-2019 08:02
Hi there,
Any other ideas on how to fix being able to see text messages on the watch?
Mine have always worked and recently stopped displaying the actual message, but will show the sender's name.
I've tried the settings that helped April out, I've uninstalled/reinstalled, resynced.. done everything I can think of. I love my Fitbit!
Any suggestions would be wonderful, thank you in advance!
Keli
07-18-2019 08:03
07-18-2019 08:03
By the way, I have a Samsung S9 Edge. And have for a year now.
07-19-2019 12:44
07-19-2019 12:44
Mine worked fine also until this last update. It still tells me the sender but doesn't give the message any more.
07-19-2019 13:10
07-19-2019 13:10
07-19-2019 13:11
07-19-2019 13:11
Darn, I thought that might be the case. Really disheartening. Thank you!
07-19-2019 19:31
07-19-2019 19:31
I'm having the same issue and I thought I was going crazy. Glad that's not the case, but wish we could still read the messages.
07-21-2019 07:05
07-21-2019 07:05
I'm having the same problem. Just recently started on my Charge 2
07-22-2019 13:09
07-22-2019 13:09
Not that this is helpful for you, but I am also suddenly having this problem. Was working fine up until maybe a week ago? I have not intentionally changed any settings on my phone (galaxy s8) or charge 2. Kinda bummed.
07-22-2019 18:21
07-22-2019 18:21
Same issue which started a little over a week ago Frustrating especially since this was one of the reasons I purchased the charge 2.
