04-30-2020
17:34
09:49
04-30-2020
17:34
09:49
I've had my FitBit Charge 2 for a while but all of a sudden it will not hold a charge. I plug it in the device indictaes a full battery but after about an hour or two it is totally drained. Any thoughts
Thanks
Chris
05-11-2020
10:07
10:40
05-11-2020
10:07
10:40
@Cfavs Thanks for stopping by! Sorry for the delay in my reply.
Let me help you with your Charge 2 not holding a charge. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help improve the battery life.
Let me know how it goes.
05-12-2020 05:16
05-12-2020 05:16
I am facing similar issue, but my fitbit charge2 battery charge won't hold more than 2-3 min.
I tried cleaning all the contacts, tried restarting, tried restarting back to back 3-4 times.
Battey shows full charge but as soon as I take out from charger my fitbit charge 2 will die out within 2-3 mins. When again connected to charger it shows battery full drained.
05-26-2020
11:21
10:40
05-26-2020
11:21
10:40
@Rakeshshekhawat Welcome to the Community. Sorry for the delay in my reply.
Let me help you with your Charge 2 battery draining quickly and thank you for troubleshooting this issue. Since the issue persists I have created a ticket so our Support team can further assist you via email.
