05-27-2018
18:57
18:54
05-27-2018
18:57
18:54
I got an iPhone X today and the phone cannot find the Charge 2 tracker. I have turned off my iPhone (bluetooth off) and turned it back on, turned bluetooth on/off, restarted my fitbit tracker, "forgot" the device from my old phone, turned my old phone off and it still can't find the device. I'm told the iPhone X is not compatible with the fitbit trackers at this point...is this true? Any help would be greatly appreciated.
05-28-2018 07:46 - edited 05-28-2018 07:48
Welcome to the Fitbit Community @kliegz, hope you're doing great today! Thanks for already troubleshooting this setup issue, nice way to go! Is your Charge 2 still not pairing to your iPhone X?
If you can't get started with your Fitbit device, usually a missing requirement is the cause. Carefully review the requirements below:
If you're still unable to set up, try the troubleshooting steps below:
PS: The iPhone X is compatible with the Fitbit app. You can see it added in our list of supported devices by clicking here.
Give this a go and let me know the outcome!
10-31-2018 13:08
10-31-2018 13:08
No matter what I do (Even with Fitbit on the phone) It will not pair. Fit bit says to call back in one or two hours. This has gone on for six months. It will not work with the iPhone X. Fit bit is selling faulty product.
10-31-2018 13:13
10-31-2018 13:13
Purchased for Christmas of 2017 when I was using an android phone. Switched phones and got a replacement charge2. Have never been able to connect the charge2 To the iPhone X. Even deleted my Fitbit account and opened up a new account. This is my sixth fit bit. And it will be my last because of customer service.
10-31-2018 13:15
10-31-2018 13:15
Purchased for Dec of 2017 when I was using an android phone. Switched phones and got a replacement charge2. Have never been able to connect the charge2 To the iPhone X. Even deleted my Fitbit account and opened up a new account. This is my sixth fit bit. And it will be my last because of customer service.
01-14-2019 07:19
01-14-2019 07:19
I've done all the things submitted by this customer and by the moderator and I still can't get the fitbit to pair with my iPhone X
01-14-2019 07:50
01-14-2019 07:50
Just out of interest what is the firmware number?
01-21-2019 10:10
01-21-2019 10:10
I got a new iPhone X in December and have been unsuccessful in getting it to pair with my FitBit Charge HR. I've tried several times, keep getting frustrated and give up. I have done everything suggested here. Has ANYONE been successful in getting this to work?
01-24-2019 07:59
01-24-2019 07:59
Unfortunately I am also in the same boat and have tried 2 new pebbles. It still does not work. I am done with Fitbit and have moved on to the Apple Watch 4.
01-25-2019 05:57
01-25-2019 05:57
I finally got mine to pair. The charge 2 will only pair with one device at a time. When I set it up I did so on my iPad, when I tried to pair with my phone it wouldn’t. When I removed the pairing from my iPad it paired right up with my phone.
@Grumpy1209 wrote:I've done all the things submitted by this customer and by the moderator and I still can't get the fitbit to pair with my iPhone X
02-09-2019 07:43
02-09-2019 07:43
Grumpy1209 got me on the right track. Surprising that this technical error is still an issue.
Anyway, I needed to unpair the Fitbit watch from my last phone. Then, I restarted the watch (uncertain that was necessary). At that point pairing with the Apple->Bluetooth app on the new phone didn’t work, because the Fitbit device isn’t visible. Instead, open the Fitbit app on the new phone and they magically find each other and sync.
09-20-2019 14:17
09-20-2019 14:17
I had to unpair from my old phone, uninstall the app, on the I-phone x, turned bluetooth off. Turned the phone off. Left for five minutes, turned the phone on, turned bluetooth on,reinstalled the app, then logged in and it finally paired my device. A hassle for sure. But now done and working again.
09-20-2019 14:24
09-20-2019 14:24
Also reset device just to be sure, every step was done.
