06-25-2019
04:59
15:06
06-25-2019
04:59
15:06
Hi! I need help with my charge 2 tracker, I cannot paired it with my samsung A7 2018 though it can detect my tracker but the problem is when I already put the 4 digit code it won't push through can anyone here help me? Thanks!
06-26-2019
09:36
11:27
06-26-2019
09:36
11:27
@AnthonyAmurao It's great to see that you've visited the Fitbit Community!
Let me help you with pairing your Charge 2 with your phone. You can try the following:
Let me know how it goes.
06-26-2019 10:09
06-26-2019 10:09
This does not help! Tried several times
06-26-2019 11:51
06-26-2019 11:51
Hi, I have the same problem. I have tried all what you have listed above and it didn't work.
I saw Samsung A7 is not compatible device. Why not???
What should A7 users do??
07-03-2019 11:46
07-03-2019 11:46
I solved my Charge 2 issue on my Samsung A8: final solution and I m perfeclty happy:
I bought a Garmin Vivosport for less than 99 Euro; it synces and pairs!
No issues encountered yet; so I recommend abandoning Fitbit....their competences and advices do not reach beyond...resetting...restarting....reinstalling....and so on....
07-03-2019 16:36
07-03-2019 16:36
I am having the same issues.
I have done everything you have suggested, yet still no change.
The message that appears, when I try to connect to Bluetooth is check settings for device. Bluetooth has been turned off on your charge 2
