01-14-2018
01:09
18:54
01-14-2018
01:09
18:54
Hi. My charge 2 stoped work. I cant Turn on and chary my watch.
01-15-2018 04:45 - edited 01-15-2018 04:47
@Emil3645 A warm welcome to our Community!!! Try cleaning your tracker's contacts with a toothpick or toothbrush and then use cotton with rubbing alcohol. After this plug it for a couple of hours. If you are using a computer make sure it is plugged directly to the usb port (don't use hubs) or you can try using an UL Listed usb wall adapter like the ones that come with phones. Also try restarting your tracker by doing the following:
Plug the charging cable to your computer or UL certified wall adapter.
Align the contacts of the tracker with the charging cable and plug it in making sure it snaps securely.
Your tracker should start charging.
Press the button for 10 to 12 seconds.
You should see your tracker's firmware version and you can now unplug your tracker.
Let me know how it goes!
01-23-2018 10:07
01-23-2018 10:07
I just got my fit bit for Christmas and it wont turn on. I tried your suggestions and there is still nothing. Anything else I can try? Thanks
01-25-2018 07:18
01-25-2018 07:18
@moptop0922 Welcome to the Fitbit Community! I hope you're doing well! Thank you for following my suggestions. If your tracker isn't lighting up even after trying my suggestions then it would be better if you either go back to the seller and request an exchange or contact our Support team for assistance. They will be able to provide options to get you back on track. You will receive an email from them.
Keep me posted!
02-09-2018 10:42
02-09-2018 10:42
I did this last night. I also cleaned the contacts on the charger itself. So far, in about 90 minutes, it has dropped from 100% to 85% with no exercise other than normal daily activities. Will continue to monitor it over time and note why activities I engage in.
11-01-2018 00:38
11-01-2018 00:38
Ive cleaned it. Held down side button. But still nothing. Ive only had it 10 months. Im really annoyed
11-03-2018 01:03
11-03-2018 01:03
Should be under warranty less than 12 months I believe
11-04-2018 10:26
11-04-2018 10:26
@Kiana1008 @Sitorgit Welcome! It's nice to have you on board! @Kiana1008 Sorry to hear that your tracker isn't working and thank you for trying the suggestions in my previous post. Usually the warranty is for 12 months like @Sitorgit mentioned. You can check the warranty details here. Still I could see that you have a ticket with Support so I wanted to know if they were able to help you?
I look forward to your reply!
06-22-2020 02:59
06-22-2020 02:59
hi
I have followed the suggestion about cleaning and restarting. Still doesn't work.
I was gifted charge 2 about 3 years ago. Any further suggestions?
Thanks
06-28-2020 15:05
06-28-2020 15:05
For anyone trying to revive a seemingly "dead" Charge 2, this works: Put the charge 2 into the charger and plug in. Press the button and hold for 4 seconds then wait a second and repeat 2 more times. The Fitbit logo should come on. If this doesn't work the first time, repeat the process a second time. It is important to stick to this timing. I have reset many smart bulbs and each has its own pattern of on/off. Hope this helps. The Charge 2 I gave to my husband after I got my new Charge 4 had this problem. I had almost given up bringing it to life. Good luck!
06-29-2020 03:13
06-29-2020 03:13
Thanks @Mallwalker47. Tried but did not work. Last option is to buy a new charger but since its an old model getting a fitbit charge is difficult. Anyway thank you for your help.
07-13-2020 10:37
07-13-2020 10:37
@ManishB @Mallwalker47 Welcome to the Community.
@ManishB Let me help you with your Charge 2 not working and thank you for troubleshooting this issue. Since the issue persists I suggest you let our Support team know about it. I noticed that you already have a ticket with them so keep working with the team to find a solution.
@Mallwalker47 thank you for sharing your suggestions in this thread.
I'll be around.
08-09-2021 17:20
08-09-2021 17:20
This did not work for me. Something may be wrong with the charger. On the face all that will show is what looks like a battery with a line in the middle which blinks a couple of times, then shuts down. Or possibly the battery is about dead and will not charge? Any ideas?
