06-26-2017
20:41
09:26
06-26-2017
20:41
09:26
Midway through a walk tonight, my Fitbit went black and will not power on. It was charged and has been working fine. I tried putting it on the the charging cable and powering it up or reseting it but had no luck. My app shows it is fully charged but of course will not sync because it has no power. Help please
08-17-2018 06:33
08-17-2018 06:33
08-22-2018 19:12
08-22-2018 19:12
My screen went blank also. I have tried all the above suggestions but mine will not even vibrate. the green lights on the underneath are flashing, and I have the clip on correctly. but it wont vibrate or turn on at all.
Any Help??
09-05-2018 07:56
09-05-2018 07:56
Thanks so much. The reset steps worked!!! Fitbits are very frustrating instruments at time!!!!
Best Answer09-27-2018 08:59
09-27-2018 08:59
I did this and it didn't work for me what should i do?
Best Answer09-27-2018 10:27
09-27-2018 10:27
01-05-2019 12:20
01-05-2019 12:20
I am not having success with a dead battery in this instance.
Best Answer01-05-2019 14:18
01-05-2019 14:18
Best Answer01-09-2019 17:30
01-09-2019 17:30
Mine randomly powered down. Won't charge. Won't reset. Nothing . Dead
01-09-2019 18:08
01-09-2019 18:08
Mine too! Completed the three times reboot once before it died. Only stayed alive for maybe an hour after that.
Best Answer04-01-2019 18:29
04-01-2019 18:29
Charge 2 won’t turn on when pressing button
Best Answer05-06-2019 01:11
05-06-2019 01:11
Mine is completely dead - been on charge for almost 1 hour no vibration no reset - is there anything I can do
Best Answer05-07-2019 23:20
05-07-2019 23:20
I've tried this process, however my Fitbit is fully charged and isn't showing up on my screen.
Best Answer05-17-2019 07:50
05-17-2019 07:50
Bought mine in April 2018 not worn it for about 2 months when I wore it for work today it worked for 2 hours then went dead, nothing works to get it working again....... just out of warranty, typical.
Best Answer05-23-2019 09:14 - last edited on 02-23-2020 17:29 by LiliyaFitbit
Charge 2 working well up till yesterday charged as normal then stopped working. Tried charging several times once it started again but only for a few minutes then dead again help please
Best Answer05-26-2019 03:53
05-26-2019 03:53
Best Answer06-17-2019 18:30
06-17-2019 18:30
This did not work for me. Do you have any other recommendations?
Best Answer06-26-2019 13:02
06-26-2019 13:02
Best Answer06-27-2019 19:50
06-27-2019 19:50
Same thing happened to my fitbit 2, I tried 5 times and still nothing has happened
Best Answer06-29-2019 12:48
06-29-2019 12:48
Depending on how long you have had your Fitbit, try emailing them, mine would not work after trying everything everybody suggested, only had mine a year.
Best Answer07-20-2019 02:17
07-20-2019 02:17
I'm having same problem I connected my Fitbit to charging cable and connected to USB port but it will not even vibrate as if its charging it does nothing
