11-15-2019
14:06
11:53
11-15-2019
14:06
11:53
I've done everything possible and my charge 2 wont connect with my phone? Any ideas or are you having the same problems?
11-15-2019 21:41
11-15-2019 21:41
Hi 👋🏻
when you say everything possible? Have you restarted the charge and what phone? Have you tried re starting that? Have you re set your charge? Have you updated the software?
Best Answer11-16-2019 10:23
11-16-2019 10:23
Hi
just an update. Charge would not sync and not discovered by Bluetooth. I could on my iPad and other devices were discoverable. Tried everything then removed device from the app and re added. Magic!
11-16-2019 10:27
11-16-2019 10:27
I'm just in the process of doing this thank you
Best Answer11-17-2019 23:48
11-17-2019 23:48
Hi 👋🏻
hope it works for you! I saw your post when I was looking for an answer so thought I’d let you know xx
Best Answer11-18-2019 00:41
11-18-2019 00:41
Same...I've tried the following:
Removed fitbit and reinstalled on app
Upgraded app
Removed app and reinstalled
Force restarted my fitbit
And I am still no further forward. I have a charge 2 also. There are hundreds of Fitbit customers affected by this issue on android and fitbit dont appear to care. I keep trying to raise this eirh them only to be told to do the above..... it doesn't bloody work 😡😡😡🤬🤬 I'm sooo annoyed and angry, I was going to be getting a fitbit for my kids for Christmas.... I won't bother now.
11-18-2019 00:56
11-18-2019 00:56
Sorry to hear you are having the same problem. Mine is still not working either so I've had to pair it with an old phone that I dont use and its working ok on there . I heat Fitbit are quite good at helping. This surprises me. I need to get back to them on this matter.
Hope we can resolve this asap
Regards
Marie
