03-30-2018
07:14
18:54
03-30-2018
07:14
18:54
Band keeps detaching from watch - it feels like it snaps back into position but doesn't stay there long - getting scared to wear it now as it keeps falling off - bought in September
10-20-2020 02:27 - edited 10-20-2020 02:28
My strap has started to split mean the small screw no longer bites. Bodged a fixed with a loop of insulating tape for now while I consider my options. Two year's usage.
10-20-2020 09:35
10-20-2020 09:35
10-20-2020 10:22
10-20-2020 10:22
I found this strap on Amazon and this is the strap FitBit 'should' have made. It fits perfectly and attaches the clip firmly.
< https://www.amazon.com/gp/product/B07CK1VZKX/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 >
10-24-2020 01:36
10-24-2020 01:36
Just fitted a brand new strap and realised that what possibly caused the old strap to split was that when taking it off to shower / charge etc that you need to be careful not to exert pressure on the strap at the attachment point in the opposite direction to the natural curve of the strap round your wrist.
10-24-2020 03:26
10-24-2020 03:26
10-26-2020 01:47 - edited 10-26-2020 01:50
The difference is that a normal watch uses a spring-bar giving the strap a fuller range of movement as you take it off. Agree, that it is a design flaw on this device but it only needs "babying" as you take it off, not in normal use.
I would argue that a bigger flaw is that the screen is all too easy to scratch and scuff which is why I cover it with a sports sweat-band when working.to avoid catching it on racking and doorways as I carry things around. They would do well to look at the Casio G-Shock range of watches to learn a lesson in how to to toughen things up to protect against the real world.
