11-20-2018
04:33
14:31
11-20-2018
04:33
14:31
Please can someone tell me how I get a 24 hour clock up as I can only get 12 hour clocks ? Does fitbit charge plan to do 24 clock? My old blaze used to have one
12-26-2019 16:02
12-26-2019 16:02
12-26-2019 16:24
12-26-2019 16:24
I’ll take a look. Thanks. Happy New Year 🎊
Best Answer01-03-2020 21:00
01-03-2020 21:00
I cannot find any gear symbol or Settings on my Charge 3 to change clock to 24hour setting
Best Answer01-03-2020 21:19
01-03-2020 21:19
Hello @rsbea1,
Welcome to the community!
It's not on your Charge 3. Please do this:
3. Select 24-hour format.
4. Sync your tracker for the setting to take effect.
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
01-03-2020 21:24
01-03-2020 21:24
Best Answer01-04-2020 02:48
01-04-2020 02:48
Best Answer01-04-2020 12:25
01-04-2020 12:25
Best Answer01-04-2020 12:56
01-04-2020 12:56
Best Answer01-11-2020 19:07
01-11-2020 19:07
It’s now 1/11/2020 and the issue has not been corrected. I was messaging someone from FitBit and she said she’d have her supervision email me in a few hours. No one has gotten back to me and that was over 7 hours ago.
Best Answer01-12-2020 02:57
01-12-2020 02:57
Best Answer01-12-2020 06:00
01-12-2020 06:00
Best Answer01-12-2020 14:42
01-12-2020 14:42
Every time I've tried this it works. Please try it again. Specifically:
4. After selecting 24 hour format. Sync your tracker, otherwise it won't take effect.
If this doesn't work. Then post a screenshot of what your settings page looks like so that we can help you further diagnose.
I hope this helps.
Best Answer01-12-2020 17:54
01-12-2020 17:54
Best Answer01-12-2020 17:55
01-12-2020 17:55
It's the 12 hours clock I'd need. The 0 is still there.
Best Answer01-13-2020 08:05
01-13-2020 08:05
Oh, I finally understand what you mean by the 'the 0 is still there'. You mean the leading zero in front of the time display, like '08:00' for 8am.
The 24 hour setting controls which number is displayed after you have reached 1pm. Is the hour displayed going to be '1' or '13'. It does not control if there's a leading zero ('1' vs. '01').
Different clock faces will have leading zero; others will not. It's strictly a function of the clock face; pick one that does.
I hope this helps.
Best Answer01-13-2020 09:33
01-13-2020 09:33
Best Answer01-13-2020 19:45
01-13-2020 19:45
Have you tried all of the clock faces? Maybe there's one that doesn't have the leading zero. I often wear the Versa 2, some clock faces have the leading zero others do not.
Best Answer01-13-2020 19:58
01-13-2020 19:58
Best Answer03-28-2020 15:30
03-28-2020 15:30
What is the "gear icon??"
Do not see it on my dashboard!
Best Answer03-29-2020 00:03
03-29-2020 00:03
