04-18-2019
08:46
11:10
04-18-2019
08:46
11:10
Hi, I am very pleased to have a clock face that I can read. Really happy it is the old Charge 2 clock face that I used to use (or nearly).
On the Charge 3 it is set up as a 24 hour clock but displaying time as if it is a 12 hour clock. Very confused earlier when I looked at the time. 04:27 is the early morning time not 16:27 in the afternoon (or even 4:27 as per old Charge 2). Is there a way to change this so as to stop any confusion?
Thanks
04-19-2019
05:36
09:13
04-19-2019
05:36
09:13
It's great to see you around @karmor.
I am glad to hear that you are satisfied with the new Charge 3 clock faces.
If your tracker isn't showing the time in the format you want, I recommend verifying this by doing the following from a computer:
Let me know the outcome.
05:36
09:13
04-19-2019
05:36
09:13
Best Answer04-26-2019 13:32
04-26-2019 13:32
Thanks,
I followed your instructions and I have changed my Charge 3 from a 12 hour to 24 hour clock face. This now shows the correct time.
07:10
09:14
04-28-2019
07:10
09:14
Those are great news @karmor, I am glad to hear that your Charge 3 is now working properly. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up!
Best Answer03-17-2020 07:14
03-17-2020 07:14
I can’t find the clock display time. What shall i do?
