05-21-2021 04:59
05-21-2021 04:59
Two days in a row, an alarm has gone off on my Charge 3 at 6:45AM. The problem is I never set this alarm, and when I go into the alarm settings, there isn't one there that matches this time.
How can I prevent this from happening again?
05-21-2021 05:31
05-21-2021 05:31
Hello @mimmyu. It's nice to see you around.
Thank you for the detailed information. This is very interesting. At this time, I recommend performing a restart to your Charge 3. For this, please follow the steps here: How do I restart my Fitbit device?
If that doesn't help, please perform a long restart by following the instructions below:
Also, if you have any other alarms activated, please try to remove them and set them one more time to see if that refreshes the performance of your Charge 3.
Hope this helps.
Best Answer06-08-2021 17:09 - edited 06-08-2021 17:10
I thought this was resolved after following the steps above, but it happened again this morning with the same alarm at 6:45AM.
I restarted the Fitbit again, but instead of the 6:45 alarm appearing in the list, a long-deleted 10pm alarm was listed. I deleted it, and the list of alarms was empty.
I checked the list again just now, 10 hours later, and the 6:45 alarm finally showed up out of nowhere. Hopefully it stays deleted this time.
Best Answer06-09-2021 04:20
06-09-2021 04:20
@mimmyu Thank you for your reply.
I appreciate your help in following the suggested tips and thanks for the rest of troubleshooting steps you tried. At this time, I recommend keeping an eye on the behavior of your Charge 3 and let me know if this happens again.
I look forward to your response.
Best Answer06-16-2022 03:37
06-16-2022 03:37
I’m having a similar issue. I set a non repeating alarm for 6:30AM a few weeks ago. Now the alarm shows dimmed on my Charge 3, and when I inspect that alarm, it shows “Alarm Off”. But sitting here at 6:30AM it just buzzed again. I will try the long reset procedure above.
Best Answer06-16-2022 03:45
06-16-2022 03:45
I am not able to do the long reset steps above. Holding the button while connected to the charger just seems to reset the device normally. It shows the smiley face but no vibrations or battery.
