05-12-2021
21:38
04:07
WilsonFitbit
05-12-2021
21:38
04:07
WilsonFitbit
Charge 3 won't recharge after going very low while downloading an update. Have tried usual fixes including cleaning charging cable, using different charger, reboot, reset etc. Charges up to about 5% then goes low again but needs to be 50% to finish update.
05-13-2021 04:14
05-13-2021 04:14
Hello @SunsetRunner. Welcome to the community forums!
Thank you for the detailed information and for the steps you've followed. At this time, I was able to see that you have followed most of the steps from the following links: Why isn't my Fitbit device's battery charging? And How do I charge my Fitbit device?.
Since the inconvenience has persisted, I recommend following one more step (this is in case you haven't done this before) and this is a long restart. A long restart is different than the basic restart and you can perform it by following the instructions here:
In addition, take into consideration the instructions from this help article: Why can't I update my Fitbit device?
Hope this helps.
