12-17-2018
14:09
14:31
12-17-2018
14:09
14:31
My watch shows a small black line across the screen at the top, where the step count is on some faces and where the battery sign is when you open the stats.
tried resetting multiple times, doesn’t work.
10-26-2020 13:21
10-26-2020 13:21
Updated. The device Fitbit sent as a replacement lasted only 4 months. The battery is OK but the screen is dead.
Well, I think I had enough. Definitely will not recommend this brand to anyone nor buy anything else from them.
Who needs weather app or payments if the screen is blackened, blurred or dead? Before selling device with such features make it last for at least 2 years.
10-26-2020 16:45
10-26-2020 16:45
10-26-2020 20:52 - edited 10-26-2020 21:50
DuracellDave, already tried that several times. It does not work. Anyway, thank you for the suggestion and the reply.
This is how the screen looks like right now. I really doubt the restart “fix” will do the trick. For me the screen is defective. Reading reviews and comments from other customers and from various sources confirms that this is not just bad luck that happened to me with two devices in less than a year.
10-27-2020 21:32
10-27-2020 21:32
Just tonight, after a month of a single line across the top of the screen, my screen decided not to turn on. A Google search led me to reset instructions. It worked... But not even 10 minutes later, the screen is black again. I have had this Fitbit for a year and a half and if this is the life length of the product, I'm done.
10-30-2020 12:44
10-30-2020 12:44
That may be the case, but as of a few days ago, my entire screen is now black.
Hard resets make it work for 2 minutes then it's black again. I had nothing to lose so I updated the tracker but the problem still remains. It's now dead in a drawer and I've purchased another brand.
02-05-2021 13:54
02-05-2021 13:54
I've been having the same problem and it's getting annoying now because the lines restrict me from reading my messages on the screen 😒
02-05-2021 17:55
02-05-2021 17:55
I had a replacement sent for my charge 3 in July, 2020. The black lines started appearing around Christmas. It was originally just one. Now there are about a dozen or so. In just 6 months, I was having the problem. I've had a Fitbit for at least 5 years, but it looks like my next tracker is going to be with a different company.
03-25-2021 12:59
03-25-2021 12:59
Hi I'm having the same problem and re-starting or changing clock face does not solve it. How did you get it sorted? Thanks Gary
04-01-2021 07:40
04-01-2021 07:40
Hello everyone. @Gazza19 Welcome to the community forums!
Thank you for the information and for all the troubleshooting steps you've tried prior to posting! I was able to see that you have reached out to our Support Team and they have provided assistance and information. Since you have received assistance from them, I suggest you to update your case if you require further assistance or if you have any additional questions about the outcome of your case.
Have a great day!
04-01-2021
14:13
04:40
WilsonFitbit
04-01-2021
14:13
04:40
WilsonFitbit
Myself and my husband both have a charge3 and they now both have black lines going through screen.
Do you know if fitbit have a fix for this.
Is there a fix for the black line across the screen seems like alot of people have the same issue.
Moderator Edit: Merged posts
04-01-2021 14:13
04-01-2021 14:13
Hi Wilson,
I have not had any assistance with my problem and would appreciate getting some!
04-02-2021 04:50
04-02-2021 04:50
@SunsetRunner @Shadowthumper87 Welcome to the community forums.
I'm sorry for the experience. I'm glad I can help and please note that for tips and suggestions, my recommendation is to visit this thread but contact the Support Team as indicated in that thread, if you require further assistance or if the inconvenience still persists.
See you around.
04-02-2021 12:07
04-02-2021 12:07
Hi, I live in Germany and my 1 yr old charge 3 has stripes on its display, too. I have tried everything and they don’t go away. Plus, the display is getting darker and darker. I can‘t See anything when I‘m outside.
And since a Couple of days, the app does not work at all. Calories won’t add up, and many more issues. I’m so frustrated! I wanted to upgrade to Versa, but now I doubt it is a clever idea. So disappointing .
04-02-2021 13:09
04-02-2021 13:09
04-08-2021
05:44
08:43
04-08-2021
05:44
08:43
Hello @SabineS1004 @SunsetRunner Welcome to the community forums.
I'm very sorry for the experience you've had and thanks for taking the time to provide your feedback. Take into consideration that if the inconvenience has persisted after following the suggested troubleshooting steps, I believe it's time to contact our Support Team for further assistance. You can click here to get connected. Make sure to explain the situation and mention the troubleshooting steps you've tried prior to posting.
