Charge 3 Bluetooth connection keeps dropping
ANSWERED
Hey! Well, searching through the forums it appears like I’m not the only one with this issue.
I have just got a Charge 3 for Xmas, replacing a Surge, paired with an iPhone 6s. Everything seems to be working ok apart from the Bluetooth connection. When the watch is initially set up it works fine, I get notifications.
However, after a few hours or after I have connected to my in car kit, the Bluetooth connection between phone & watch appears to be lost, i no longer receive notifications & I can no longer access the notification menu on the app or select all day sync. When I try to access it I am told I need to pair my phone to the watch before I can use this feature! When I try to set it up I will receive a warning after 5ish minutes informing me the Bluetooth set up has failed! If I go into my phone Bluetooth settings it tells me I have a connection to the watch, but the app disagrees!
The only way way I can get the notifications working again is if I forget the Bluetooth connection on my phone, forget the Charge 3, uninstall the app & start all over again! This will make the notifications work again, but only for a few hours or until it receives another Bluetooth connection.
To say it’s a pain is an understatement, I have seen people saying it could be down to multiple Bluetooth connections, which strikes me as odd, why can’t this watch & phone handle multiple connections? I only have the one Fitbit synced to the one phone.
I’m not an expert in Bluetooth or Fitbit technology but it seems like the Bluetooth is turning off, for some reason, & the only way to turn it back on is to put  the watch back into set up mode! Is there a menu on the Fitbit to physically turn Bluetooth off & on or put it into pair mode?
Come on Fitbit, I want to keep & use the Charge 3, but this issue is frustrating, my Surge worked a lot better than this! Is it time to return the Charge 3 & return to the Surge?
145 REPLIES 145
Missed my Apple watch series 1 too however it had a dreadful battery life.
I wear my Inspire HR to bed to track sleep so I need something more comfortable with longer battery life.
It's a shame about Fitibt's poor reliability, lucky I stumbled across this thread as I was going to buy another version of Fitbit.
I believe it is a ploy to force you to buy
No reason for it
Thanks for your response
Sent from my iPhone
I am using a brand new iPhone XR and have this same issue.  All is updated and the Fitbit is 3 weeks old.  It will not sync and then hours later it will.  When I wear my cordless Bluetooth headphones I have to forget the fitbit device as every 15 to 30 seconds it says "Bluetooth disconnected" "Bluetooth connected" through the headphones telling me that the Fitbit is drooping and then reconnecting.  I have yet to refresh the fitbit app and have it do it successfully with this phone.  I have issues, but not as bad with my iPad and older iPhone 7.
Thus far I am very disappointed with Fitbit and wished I had done more shopping around for a tracker.
I have iPhone 7
Would not dray connected to Fitbit alta my fav
So I bought versa 3
So far connected
I believe it is a software ploy so you’ll purchase new
Sent from my iPhone
Hello, don’t know if this will help but it worked so far for me. Mine would not stay synced with phone. Went into Fitbit settings and turned on all day sync and so far it’s not disconnecting its self.
Thanks I’ll try
Sent from my iPhone
Mine has always been set to all day syncing. I just mailed mine for the 2nd time to Square Trade for repair.  All they do is reset & reinstall which is what I have done. I guess I’m glad I bought insurance with this piece of junk.
I hear that it’s ashame I loved my Fitbit Alta it now just sits on my nightstand
Fitbit should fix this! I’m sure it’s a software issue
Sent from my iPhone
I have three different devices and it does the same on all three.  I can do all you show above and it still does not work.
Right. They need to fix this!
Sent from my iPhone
I learned this after some time in ANDROID we have option of Battery Optimisation mode.
In this you may need to remove Bluetooth and Fitbit App both.
Goto >> Battery>> Usage>>three dots>optimise>all apps deselect fitbit and blutetooth
It should I deserve a free fitbit from fitbit company after solving this issue without any penny
I’ll try this! I’m willing to try anything at this point. Will let you know
Sent from my iPhone
This new Charge 4 is a piece of crap.  I have only had this watch for a few weeks. It continually keeps dropping blue tooth and making me disconnect and start over from the beginning.  Every single day.  I never had this with my Alta HR EVER.  Open to suggestions  before I ship this back for my cash back.
Is it your android phone,please remove Bluetooth and Fitbit app from Battery Optimiser option under battery
Sent from my iPhone
Send it back
It is never going to work
There is a software glitch that has never been fixed. They downloaded new software to accommodate the more expensive watches and messed up the alta which I loved. Mine still sits on my nightstand full charged and will not operate because of Bluetooth
Sorry
Sent from my iPhone
I have I phone?
Sent from my iPhone
Return it. Get a Garmin Forerunner 645!
Having the same issue with charge 4 and iphone x. Everything is iodate reset everything and still drops connection every 10 mins.
spoke to fitbit today and they are sending a replacment im just hoping that doesnt have the same issue.
Wth is going on that these devices are having this issue
Sent from my iPhone
Since the latest update, my Charge 3 will not stay paired with my iPhone 11 Pro and I cannot find the silent alarms.
