01-02-2019
11:20
10:34
WilsonFitbit
01-02-2019
11:20
10:34
WilsonFitbit
Hey! Well, searching through the forums it appears like I’m not the only one with this issue.
I have just got a Charge 3 for Xmas, replacing a Surge, paired with an iPhone 6s. Everything seems to be working ok apart from the Bluetooth connection. When the watch is initially set up it works fine, I get notifications.
However, after a few hours or after I have connected to my in car kit, the Bluetooth connection between phone & watch appears to be lost, i no longer receive notifications & I can no longer access the notification menu on the app or select all day sync. When I try to access it I am told I need to pair my phone to the watch before I can use this feature! When I try to set it up I will receive a warning after 5ish minutes informing me the Bluetooth set up has failed! If I go into my phone Bluetooth settings it tells me I have a connection to the watch, but the app disagrees!
The only way way I can get the notifications working again is if I forget the Bluetooth connection on my phone, forget the Charge 3, uninstall the app & start all over again! This will make the notifications work again, but only for a few hours or until it receives another Bluetooth connection.
To say it’s a pain is an understatement, I have seen people saying it could be down to multiple Bluetooth connections, which strikes me as odd, why can’t this watch & phone handle multiple connections? I only have the one Fitbit synced to the one phone.
I’m not an expert in Bluetooth or Fitbit technology but it seems like the Bluetooth is turning off, for some reason, & the only way to turn it back on is to put the watch back into set up mode! Is there a menu on the Fitbit to physically turn Bluetooth off & on or put it into pair mode?
Come on Fitbit, I want to keep & use the Charge 3, but this issue is frustrating, my Surge worked a lot better than this! Is it time to return the Charge 3 & return to the Surge?
01-02-2020 11:34 - last edited on 02-14-2020 17:40 by LiliyaFitbit
I agree. I can’t return my at this point. I wear it once in a while to make my husband happy. He meant well and I do appreciate his thoughtfulness.
From my iPad
Best Answer01-02-2020 15:36
01-02-2020 15:36
Best Answer01-03-2020 05:10
01-03-2020 05:10
Sorry to hear that. My apps transferred from my iPhone, and I’ve got everything I need, plus energy calories and as always steps. Good luck.
Best Answer01-03-2020 14:01 - last edited on 02-14-2020 17:39 by LiliyaFitbit
Not all of my apps transferred from my phone to my watch. And some are incompatible. So, I’ve had to work around the issue.
From my iPad
Best Answer01-03-2020 16:37
01-03-2020 16:37
Best Answer01-03-2020 23:14
01-03-2020 23:14
01-04-2020 07:19
01-04-2020 07:19
01-06-2020 23:19
01-06-2020 23:19
I’m having the exact same problem with Bluetooth dropping off and no notifications and it’s only been since I updated my Fitbit.
I have tried the troubleshooting steps it doesn’t help at all.
Fitbit, Is there anyway I can return this watch for one that works? Or is there going to be a fix brought out?
Thanks,
Nicola
01-07-2020 08:46
01-07-2020 08:46
02-01-2020 08:04
02-01-2020 08:04
I have had the same problem with bluetooth dropping my Charge 3 every day. And like others, it was working fine before the OS13 update. I have an Apple 11 so the problem is not limited to older phones.
02-01-2020 09:21
02-01-2020 09:21
Best Answer02-01-2020 10:19
02-01-2020 10:19
Best Answer02-02-2020 04:14
02-02-2020 04:14
02-03-2020 04:58
02-03-2020 04:58
Best Answer02-03-2020 09:41
02-03-2020 09:41
Best Answer04-21-2020 04:56
04-21-2020 04:56
Has a fix come out?
Best Answer04-21-2020 04:59
04-21-2020 04:59
Has this been fixed
Best Answer04-21-2020 06:40
04-21-2020 06:40
Best Answer04-21-2020 06:55
04-21-2020 06:55
Best Answer04-21-2020 09:53
04-21-2020 09:53
Apple Watch series 4 from Costco. (I did not get the one with the phone.) Works every time with no issues and has never “dropped “ the Bluetooth connection. It still records steps and much more. I am happy happy with the purchase and won’t go back o Fitbit.
