05-31-2021
01:16
04:11
WilsonFitbit
05-31-2021
01:16
04:11
WilsonFitbit
A couple of days ago following a message that said "database updated" or words to that effect, my tracker stopped connecting to the app. I have rebooted the tracker a few times but still no success. The computer recognises the tracker but states that Bluetooth is off. Any assistance would be appreciated.
Thanks
05-31-2021 04:17
05-31-2021 04:17
Hello @divvy47. Welcome to the community forums!
Thank you for the detailed information and for the steps you've tried prior to posting. If your Computer is running Windows 10, I'd like to let you know that the Charge 3 isn't supported on this operating system and it would require a compatible Android Phone, iPhone or iPad for the set up and syncing process. For more information about compatible devices, please check here.
If this is not the case and if you have un-paired your Charge 3, I recommend setting it up again by following the instructions in these help articles: How do I set up my Fitbit device? And Why can't I set up my Fitbit device?
In addition, while you have restarted your Charge 3, I recommend performing a long restart. A long restart is different than the basic one and you can follow the instructions below to complete it:
Hope this helps.
Best Answer05-31-2021 04:17
05-31-2021 04:17
Hope this helps.
Best Answer05-31-2021 05:07
05-31-2021 05:07
Thanks for the quick response. I have a windows 10 computer and the fitbit app has been working fine for well over a year until recently. Following you comments I have tried to carry out a long restart but am not getting the progress bar you mentioned. I tried pairing the tracker on my device but it needs a 4 letter/number code which I don't have. I seem to remember inputting the code at the initial setup but haven't kept the details (my bad). Any suggestions on how to proceed.
Thanks
Best Answer06-03-2021 05:02
06-03-2021 05:02
Issue now resolved by concentrating on my device rather than the pc. There were/are connectivity issues but at least I now have a tracker that syncs.
Thanks
Best Answer06-03-2021 05:10
06-03-2021 05:10
@divvy47 Thank you for your replies.
I also appreciate the detailed information and thank you very much for your efforts and for the steps you've followed. I'm glad to hear that your Charge 3 is now syncing and I hope you can continue tracking towards your fitness goals.
Have a great day.
