05-30-2019
05:04
10:58
05-30-2019
05:04
10:58
The button on my Fitbit is stuck in and I can’t get it to pop back out. Consequently I have a blank screen. It still vibrates and counts my steps.
08-31-2019 18:27
08-31-2019 18:27
I am also having the same issue. The haptic button doesn't respond to anything. It won't even reset. So frustrating!!!
Best Answer08-31-2019 19:22
08-31-2019 19:22
Best Answer09-02-2019 09:43
09-02-2019 09:43
Hi @TeppiWoman, welcome to the Community Forums. Thanks for already troubleshooting your Charge 3.
I was about to create a support case on your behalf, but I've seen you contacted our Support Team after posting here and that they have helped you with this. Keep an eye on your inbox for updates on your case.
Thanks for your advice @Libbymary.
Let us know if there's anything else we may do to assist you with.
Best Answer10-11-2019 19:06
10-11-2019 19:06
Mine has just had this happen. I have tried everything. Help. Feel naked without it on. Tried the restart and nothing. Button stuck. Mine is the Charge 3. Mine looks like the photo attachment.
Best Answer10-12-2019 13:37
10-12-2019 13:37
10-14-2019 08:28
10-14-2019 08:28
Hi @MontanaMom, welcome to the Community Forums. Thank you so much for all the steps you tried prior to contacting us.
I was about to create a support case on your behalf, but I've seen you contacted our Support Team after posting here and that they have helped you with this. Please keep an eye on your inbox for updates on your case.
Hey there @Pacampos, thanks for you advice. I'm glad to hear that our Support Team sent you a new device. I hope you're enjoying it! 😊
I'll be around if there's anything else I may do to help you both. Have a great day!
Best Answer10-23-2019 13:53
10-23-2019 13:53
Hi, I just got the watch replacement part and it won't charge. Not sure what to do next. Thanks
Best Answer10-23-2019 16:47
10-23-2019 16:47
Best Answer10-23-2019 18:00
10-23-2019 18:00
10-24-2019 19:24
10-24-2019 19:24
Best Answer06-15-2020 15:35
06-15-2020 15:35
Hi, my side button is stuck flat and cannot be pressed. It will not release after trying all the suggestions you offered. It wont make contact on the charge plug and isn't showing any power now. Haven't had any problems until recently when it just stuck. Please help!!!!!
Best Answer07-15-2020 08:44 - edited 07-15-2020 11:53
Same exact problem here. My Charge 3 is totally nonresponsive. @MarreFitbit, should I open a support ticket?
Best Answer07-15-2020 10:49
07-15-2020 10:49
Best Answer11-08-2020 18:48
11-08-2020 18:48
This haptic issue began after the last firmware update. I called customer support and went through the troubleshooting with no luck. All I got offered was 30% off a new fitbit since this happened after the 1st year was up. I don't feel this is fair since it seemed to have happened after the firmware update. Is this really the best fitbit can do?
11-08-2020 20:34
11-08-2020 20:34
Best Answer01-01-2021 08:32
01-01-2021 08:32
My Fitbit button has pushed in flat and will no longer allow me to change screens. Please help.
Best Answer02-04-2021 02:41
02-04-2021 02:41
Yep, am now having the exact same issue. Button stuck in, put it on charge and it feels like its going to overheat, screen wont turn on and wont sync.
Best Answer02-04-2021 08:09
02-04-2021 08:09
16:15
06:04
JuanJoFitbit
02-06-2021
16:15
06:04
JuanJoFitbit
Hi my charge 3 button is also stuck.
The reset did not work either and my button is stuck when I reset and take it off charge and back on it just automatically resets again as if the button is stuck still holding down
Moderator edit: merged reply
Best Answer02-07-2021 08:43
02-07-2021 08:43
