04-13-2021
04:01
06:01
WilsonFitbit
04-13-2021
04:01
06:01
WilsonFitbit
Hi. I want clarification please I have a Fitbit charge 3 I am 68 years old. Regarding the heart rate tile in my app regarding my cardio fitness score it fluctuates. It has been 44/48 today it’s 45/49. It’s says that’s excellent. What am I aiming for ? A lower or higher reading many thanks. Fran
Moderator edit: subject for clarity/label
04-22-2021 09:00
04-22-2021 09:00
@Judaskiss Thanks for your reply.
I'm sorry for any inconvenience. As you know, your Cardio Score is based primarily upon your resting heart rate. So, this means that as long as your resting heart rate is lower, the better your score.
Currently, my resting heart rate is usually in the mid to upper 50s so I have a good score but my sister's resting heart rate was near 90 and that was apparently the cause of her poor score.
So, if you're receiving a Cardio Score between 42/46 and 45/49 and considered Excellent range, it could indicate that it is well for your age. (As mentioned above), the lower your resting heart rate the better your score.
In this case you have to keep an eye on your Resting Heart Rate. Resting heart rate is the number of times your heart beats per minute and typically, resting heart rate ranges from 60-100 bpm, but the rate can vary based on age and fitness level.
Note that Heart rate varies from person to person and day-to-day. But if you notice discrepancies with your Resting Heart Rate and Cardio Score, it’s worth mentioning it to your doctor.
Hope this explains your inquiry.
04-14-2021 06:05
04-14-2021 06:05
Hello @Judaskiss. Welcome to the community forums!
Thank you very much for the information. I'd like to let you know that your cardio fitness score is determined by your resting heart rate, age, gender, weight, and other personal information. For best results, make sure your weight is correct in your Fitbit profile. Also, wear your tracker or watch to sleep for a better resting heart rate estimate. Your cardio fitness score will be shown as a range unless you use GPS for runs.
Your cardio fitness score will fall into 1 of 6 cardio fitness levels that range from poor to excellent. These levels are based on published data that help show how your cardio fitness score compares to others who are the same age range and sex (source).
For more information about Cardio Fitness Score, I recommend visiting the following link: What is my cardio fitness score?
Hope this helps.
04-14-2021 11:10
04-14-2021 11:10
04-22-2021 09:00
04-22-2021 09:00
04-23-2021 03:24
04-23-2021 03:24
04-24-2021 04:47
