02-16-2022 11:49
02-16-2022 11:49
I am having an issue with my charge 3. My wristband broke so I bought a new one to replace it but the button you press to release the wrist band doesn’t work.
It’s completely numb and can’t be moved at all.
One side works as it should but not the other side.
I brought it into the shop where I bought it and they said to contact fitbit because they are not allowed to try and fix it.
02-16-2022
18:29
07:39
02-16-2022
18:29
07:39
@Saraflyckt , Nice to see you here. Thank you for your message and feedback.
The best place for our team to have a look at your case, is our Support team. Please give them a call or chat with us. Please have the receipt at hand.
Click here to get connected.
See you around.
22:43
05:57
AndreaFitbit
02-16-2022
22:43
05:57
AndreaFitbit
Thank you Juan. I’ve tried to use the chat function but unfortunately it doesn’t work
Moderator edit: removed personal information.
Best Answer02-17-2022 17:13
02-17-2022 17:13
@Saraflyckt , Thank you for your message.
Where are you located?
Please on the contact site, scroll down, and make sure that your country is selected to see the options available on your region.
You'll see a flag on the bottom of the site. Click on it to change your location.
If you are still having difficulties, let me know
See you around
22:22
17:01
JuanFitbit
02-17-2022
22:22
17:01
JuanFitbit
Sweden 🌸
Sara
Best Answer02-20-2022 17:03
02-20-2022 17:03
@Saraflyckt , Thank you for your reply.
Please try this link for the Swedish Support.
https://myhelp.fitbit.com/s/support?language=en_US&co=SE
Hope this helps.
