10-22-2018
20:55
15:03
10-22-2018
20:55
15:03
I've had my Charge 3 just over a week. When I got it, it charged right up just fine. Now the battery is about to die and it doesn't want to charge. It seems like the cable isn't connecting or recognizing it. No notification of a charge comes on screen. It doesn't vibrate when the clip connects. I've quadrupled checked the alignment of the pins and it doesn't seem to be dirty. I've also tried different ports on my computer, my boyfriend's computer, and a pocket charger, but nothing. I keep trying to restart it, but it seems like it it won't even restart unless its plugged into power, which I can't get it to do. Any idea? Is it a dud?
Moderator Edit: Updated Subject for Clarity
02-27-2019 09:03
02-27-2019 09:03
Found the number in the app and called. Mine fitbit won't restart like they suggested so someone is contacting me within 48 hours and most likely replacing it for me.
02-27-2019 09:14
02-27-2019 09:14
Hello all, I hope you are doing fine.
I appreciate all the efforts in trying to fix this battery issue by yourselves.
@Yaranna, @ldifranc and @JessiLee1516, upon checking with our support team, I was told that you have already created a case with them. Please stay tuned to your email to see the steps to follow.
@Tophen, since the steps you tried didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
Keep me posted.
02-28-2019 20:25
02-28-2019 20:25
Hi there, I am emailing about the below issue that user HolliM has had with her firbit charge, I am currently having the exact same issue, can you tell me how his can be resolved or weather it is faulty ? I have had it since the 1st of December
realy looking forward to your reply
many thanks in advance
mel
03-01-2019 00:54
03-01-2019 00:54
I have the same issue and mine is only 2 weeks old
03-04-2019 08:35
03-04-2019 08:35
Hey @Mel_ma, welcome to the Community and @TFDrummond it's great to see you around.
I appreciate all the efforts in trying to fix this battery issue by yourselves. If your trackers aren't charging, I recommend taking a look at the help article Why isn't my battery charging? and follow the instructions provide there.
I hope this helps, let me know how it goes.
03-04-2019 14:31
03-04-2019 14:31
03-05-2019 06:16
03-05-2019 06:16
Hi. My charge3 has just stopped charging. I went and bought another charger today, and still nothing but a smiley face and a couple vibrations.
03-17-2019 02:09
03-17-2019 02:09
My Charge 3 is totally dead and it will not charge at all !!
I did everything else what can I do next ? Bring it back to the store I bought it from ? I'm not happy !!!
03-17-2019 06:07
03-17-2019 06:07
03-19-2019 06:11
03-19-2019 06:11
I have the same issue. Brand new charge 3, charged first time but now won’t charge at all. I have tried many different ports and devices and at times it will start to charge but then after a minute or so it stops. I believe there may be something wrong with the cable. Is it possible to get a new one?
03-19-2019 06:34
03-19-2019 06:34
03-19-2019 06:56
03-19-2019 06:56
03-19-2019 07:11
03-19-2019 07:11
03-19-2019 08:30 - last edited on 01-26-2020 14:35 by LiliyaFitbit
Hi,
I returned my Charge 3 within four days of buying. And now I'm scared of
buying another one. I think even Versa has a very similar cable.
It's an expensive gadget and I think I'll buy it once Fitbit resolves such
petty issues.
03-26-2019 04:25
03-26-2019 04:25
I have had my Fitbit charge 3 since January and all of a sudden it stopped charging. Tried all the remedies that everyone else has tried and still no luck can you help!!!!
03-26-2019 05:15
03-26-2019 05:15
03-27-2019 05:41
03-27-2019 05:41
Hello guys, thanks for your participation in the Community.
I am sorry for the delay in respond. @JessiLee1516, thanks for the input.
@Mel_ma, it's great to hear that you received a replacement. At the moment of receiving it, you can follow the instructions provided in the help article How do I set up my Fitbit device? to set it up.
@GAlexandra, @EileenaLennox, @yashfame, @CB45 and @Veers83, if your Charge 3 aren't charging, I recommend taking a look at the help article Why isn't my battery charging on my Fitbit device? and follow the instructions provided there.
See you later.
03-27-2019 18:16
03-27-2019 18:16
I'm having the same issue. I tried numerous usb ports and have cleaned and checked the connection. I've had the charge 3 for about 3 weeks and it's charged fine until now.
Paula
03-28-2019 22:17
03-28-2019 22:17
Must be a bad batch of cables or something. Mine has gone bad as well.
03-30-2019 21:02
03-30-2019 21:02
I have this exact same problem but the answer provided didn't answer the question. Help!
