11-02-2018
06:50
15:03
11-02-2018
06:50
15:03
My Charge 3 is not even a month old and the bands are falling off. It seems the clips on the Charge 3 are failing already.
This is happening with original and accessory bands.
I've been chatting with Fitbit via Twitter Direct Messaging about this. Gonna have to get on the phone and request a warranty replacement it seems. In case you need it here is Fitbits phone number 877-623-4997
01-26-2020 18:55
01-26-2020 18:55
01-26-2020 19:36
01-26-2020 19:36
Was less than a year
01-26-2020 19:39
01-26-2020 19:39
Then why sale such a cheap band for a device that’s costs $200 plus dollars? The least they could do is attach a band of good quality
01-26-2020 20:23
02-22-2020 05:44
02-22-2020 05:44
They don’t work either. My kids gave me a Fitbit Charge 3 and also bought extra bands like these. The fall right off.
02-22-2020 14:14
02-22-2020 14:14
02-22-2020 18:10
02-22-2020 18:10
Well that sounds simple enough! I will definitely try that!
Thanks!
04-28-2020 00:13
04-28-2020 00:13
Yes, me too. Only had mine 5 days. First it fell off while sleeping and a couple times while I was dressing. Annoying, but I just reattached it. Then the **ahem** thing fell off while I was getting my bike ready for a ride and I didn’t notice until a couple hours later and tried to retrace where I was and couldn’t find it. Come to find out this has been an issue with the bands for a couple years? Now I’m just angry and feel ripped off.
04-28-2020 09:53
04-28-2020 09:53
04-28-2020 10:02 - last edited on 09-30-2020 20:23 by LiliyaFitbit
I did contact them and they had me return the Fitbit in exchange for a new
one that works great.
Sincerely,
*“Living well and beautifully and justly are all one thing “ *
* -- Socrates*
04-28-2020 16:51
04-28-2020 16:51
07-06-2020 18:48
07-06-2020 18:48
My band with the holes for my Fitbit Charge 3 keeps falling off. Unfortunately, it isn't covered by warranty anymore and it was a gift, so by Fitbit warranty policy I wouldn't be able to file a claim for repair even if it was within the warranty period.
I've tried cleaning the connector part of the band and the Fitbit connection with some water and a cotton swab, but I still have no luck. Does anyone have any suggestions for what else I can do to try to mitigate this issue?
07-06-2020 19:17
07-06-2020 19:17
An update for those of you still reading this. I found that the springs under the band holder needed some love so it may be an easy fix for some of you out there too. I just used a sewing needle to get underneath of it and clean the springs as best I could. If that still doesn't work for you all, and the warranty is expired, I found an affordable fix with this YouTube video. Hope this helps!
09-11-2020 21:26
09-11-2020 21:26
i want to share mt my experience as well, not a pleasant one. I bought FitBit Charge 3 and the its less than a year old and the band is cracking and breaking off. I had also bought extended warranty on top of the actual price but when i went back to the shop to get it fixed they are saying that its not covered under manufacture warranty when clearly its a manufacturing defect as the crack in the wrist band appears to be originating from the dot indentation which is a bad design and needs to be fixed or replaced by manufacturer.
09-12-2020 16:18
09-12-2020 16:18
Hi @Suri09 you mention going back to the shop where you bought the Charge 3.
Is this extended warranty purchased through Fitbit or through "the shop" the tracker was purchased through?
The extended Fitbit warranty does not go into effect until the Fitbit warranty expires.
I'm not sure what extended warranty you purchased.
Who is the extended warranty with and was the Charge 3 bought through Fitbit?
As for bands breaking, some waranties do not cover physical damage to accessories.
With replacements at about 10USD for nice metal bands just saying that it really is not worth the hassle.
09-13-2020 09:17
09-13-2020 09:17
I do not think fitbit makes a band that does not fall off.
09-30-2020 16:13
09-30-2020 16:13
Mine too.. so frustrated. I go kayaking and dropped off into the river. Gone forever. I bought a new Charge 4 to replace it. If that happens again I’m giving up on Fitbit.
09-30-2020 16:27
09-30-2020 16:27
My husband bought an off-brand band that has ALLOT of holes and a small metal holder. It was the solution I needed since Fitbit won't fix their own problem!
09-30-2020 22:07
09-30-2020 22:07
09-30-2020 22:11
09-30-2020 22:11
