12-31-2018
14:36
20:07
12-31-2018
14:36
20:07
I can't find a way to sync my Charge 3 to my computer, ( the Fitbit web site says that I should be able to.) The "Chat Room" assistant says I can't connect unless I have a "smart" phone. I activated my Charge 3 with a borrowed "Smart Phone" and it works fine, except that I can't find a way to sync the Charge 3 watch with the computer. For a price tag of $150 it would seem that the Charge 3 would be more compatible, unless this is a Fitbit marketing scheme.
01-01-2019 00:44
01-01-2019 00:44
Now that you have been through the setup process you should be able to sync with a computer but it depends on what computer you have.
The simplest is if you are running Windows 10 and the computer has inbuilt bluetooth. In this situation you can download the fitbit app from the microsoft store and that will be able to sync your fitbit.
If you are running an earlier version of Windows then that app will not be available. Instead you will need to download the "fitbit connect" software from www.fitbit.com/setup Unfortunately this software will not work with inbuilt bluetooth and you will need a fitbit wireless dongle which doesn't come with the Charge 3 and would need to be purchased.
Mac computers would need to use the fitbit connect software but they may work with inbuilt bluetooth.
Best Answer01-08-2019 01:03
01-08-2019 01:03
Steve, thank you for your help. I already have "fitbit connect" and a fitbit dongle that syncs my Charge HR with my computer. I am running Win 7 on my computer and can't find a way to add my Charge 3 to my account to sync with my computer. Any ideas on the procedure? Thanks.
Best Answer01-08-2019 01:23
01-08-2019 01:23
I'm not currently running fitbit connect (I have Windows 10 so use the app instead) and I'm struggling to remember the process. I did though find this buried in the help files:
taken from: https://help.fitbit.com/articles/en_US/Help_article/1873/
Best Answer01-08-2019 08:55
01-08-2019 08:55
