11-11-2018 07:19 - last edited on 11-17-2020 15:03 by MatthewFitbit
With Charge 2 after a run without my phone I could see the map with pace and time. Charge 3 does not do that. And all my GPS system on phone and device are on
04-07-2020 15:33
04-07-2020 15:33
In further update, I disable my WIFI before each run, launch the Fitbit app and sync/refresh. Then go to the Fitbit (Charge 3), press menu button, click into Exercise, Run and connect to Phone via app and start! This gives me an accurate read of mileage and other data. It also gives the map which was my original issue. Unfortunately you need your phone’s GPS, which is a bit retrograde!
To confirm that the GPS is on, whilst on Run screen on device, Swipe/Scroll Up. You should see the setting Use Phone GPS and Run Detect - make sure these two are switched on. This is a one-time change.
04-07-2020 15:34
04-07-2020 15:34
Great question! Following! My workaround is to use the phone’s GPS functionality, linked to the app and device.
04-07-2020 16:44
04-07-2020 16:44
09-04-2020 01:33
09-04-2020 01:33
I'm having the same issues, Fitbit just stopped mapping the run even though no settings were changed. Usually I just open the app as I have location settings to only while using the app, then I start my run from my charge 3, but now it doesn't map the run. Very very annoying! Has anyone found a fix for it yet?
09-04-2020 10:38
09-04-2020 10:38
Yes the fix involved:
confirming you have the most updated application
switching off the GPS and Bluetooth functionality on both phone and watch
switching off the WiFi and using current mobile service provider
switch on GPS and Bluetooth back on both devices
launch app on watch, open app on mobile and confirm location services enabled
start app on watch and start running
after doing this once, the map functionality was restored
turn back on Your WIFi on phone
good luck
09-07-2020 06:27
09-07-2020 06:27
Thanks,
I'll give it a try in the morning
11-08-2020 07:35
11-08-2020 07:35
Hi,
few months ago my device stopped tracking my run on map - I checked it in every way and all shgould be fine - what is happening, it's showing only start and end point on the map, nothing in between - no tracking data, no data about every mile, just overall resume of whole run. It wasn't issue on my charge 2 and at begininning of usage of charge 3...
01-03-2021 19:48
01-03-2021 19:48
I believe this is due to a change to the default location services permissions introduced in android 10 which now only allows access to device location when the app is being used as a default. To resolve go to settings>apps>fitbit>permissions>location and change from "Allow only while using the app" to "Allow all the time".
