01-03-2019
02:14
06:36
WilsonFitbit
01-03-2019
02:14
06:36
WilsonFitbit
For my Charge 3 , No Green light behind the device and display is blank. It was vibrating but now it stopped. Charge 3 is 1 month old.
01-03-2019 02:24
01-03-2019 02:24
You could try restarting it by:
01-03-2019 03:43
01-03-2019 03:43
Hi Steve ,
Thank you. It is working fine now.
01-03-2019 14:56
01-03-2019 14:56
Mine went black yesterday, no green light either. Did the 8 second reset and the 15 second rest and nothing. It's only a month and half old, help please
01-04-2019 00:51
01-04-2019 00:51
Try below steps.
1. Plug device to Charging cable and connect to your laptop.
2. Press side button for few seconds till you get smile symbol. dont do long press. 10 seconds will be enough or repeat it again.
3. Once you get smile symbol , continue to charge the device.
Hopre it works.
02-20-2019 07:45
02-20-2019 07:45
And if you do not get a smiley face? What then?
03-22-2019 10:22
03-22-2019 10:22
I tried all of the following steps and my fitbit charge 3 will not power on, will not vibrate, will not light up, nothing. Charged over night and for the last 3 hours and nothing.
03-27-2019 09:03
03-27-2019 09:03
I have no green light and yet the fitbit Charge 3 does vibrate when on my wrist. I have tried holding the restart button in the charger base plugged in and sometimes I get the smile and sometimes not. I have tried changing the clock face and the message comes back unable to sync with fitbit so it is not receiving instructions. The green light has not come on. The watch is 3 months old and a gift so I don't have the receipt.
03-28-2019 06:15
03-28-2019 06:15
I have the same trouble as this person. /have been unable to sync it also.
Have tried holding the restart button in the charger base plugged in and sometimes I get the smile and sometimes not. I have tried changing the clock face and the message comes back unable to sync with fitbit so it is not receiving instructions. The green light has not come on. The watch is 3 months old and a gift so I don't have the receipt.
03-31-2019 16:47
03-31-2019 16:47
My Charge 3 has no lights on the back and does vibrate if I push the side button but despite smily face sometimes appearing and leaving it on charge it is still not turning on. Purchased in Jan 2019 at Changi airport.
05-02-2019 13:10
05-02-2019 13:10
I am having the same problem after the upgrade.
05-02-2019 13:13
05-02-2019 13:13
My charge3 has been replaced and did upgrade this morning,all ok. I spoke to fit bit and found them really helpful. They will also walk through trying to get the unit working.
05-02-2019 13:15
05-02-2019 13:15
I have tried several times, I get the smiley face but no vibrate, and no lights. I is tracking some items but not all.
05-12-2019 15:52
05-12-2019 15:52
Mine is doing the same thing
no lights coming on, it won’t charge, it won’t sync but it does give me a long vibration that’s it .
06-01-2019 19:16
06-01-2019 19:16
Has Fitbit come up with a solution? Many of us depend on these devices for different reasons..... pretty expensive bracelet.
No reset, deletion of app, forgetting of device etc has worked. What is the solution?
06-01-2019 19:32
06-01-2019 19:32
Same experience.
06-01-2019 19:34
06-01-2019 19:34
The charge 3 is junk and I’m on my replacement in last 5 months and doesn’t work after trying all the trouble shooting.
06-02-2019 07:55
06-02-2019 07:55
06-26-2019 14:05
06-26-2019 14:05
I’m having the same problem - have tried the advise given still not working .
Please help
08-20-2019 06:43
08-20-2019 06:43
This worked! Thank you! I've had my Fitbit Charge 3 for about six months. This morning the screen wouldn't light up, the button was not working, it wouldn't charge, there was a green and red light constantly flickering on the back and it wouldn't connect with the app. I connected it with the charger and held the button for 8 seconds. Voila! A smiley face showed up on the screen and now all is well. Thank you for posting this!
