06-12-2021 11:39 - last edited on 06-14-2021 05:06 by WilsonFitbit
Green light ie. heart rate monitor on reverse side is off so not reading sleep, active minutes etc.
06-14-2021 05:10 - edited 06-14-2021 05:12
Hello @Simon012. Welcome to the community forums!
Thank you for the detailed information. Please make sure that the Heart Rate setting on your Charge 3 is On, for this, go to the Settings app on your Charge 3 and you will find the Heart Rate setting where you can make changes. If you have any inconveniences to navigate your Charge 3, please check: How do I navigate my Fitbit device?
On a side note, I recommend performing a restart by following the instructions here: How do I restart my Fitbit device?
Hope this helps.
06-14-2021 05:23
06-14-2021 05:23
06-15-2021 17:56
06-15-2021 17:56
I am having the same problem. No green light and no heart or sleep readings since June 12th.
06-16-2021 04:08 - edited 06-16-2021 04:09
Hello @Vixxxx. Welcome to the community forums! @Simon012 Thank you for your reply!
At this moment, I'd recommend performing a long restart to your Charge 3 trackers. A long restart is different than the basic restart and you can complete it by following the instructions below:
Hope this helps.
06-17-2021 02:52
06-17-2021 02:52
06-17-2021 04:45
06-17-2021 04:45
@Vixxxx Thank you for following the suggested steps.
I'm sorry for any inconvenience caused. Since the issue has persisted, my best recommendation is that you please reach out to our Support Team for further assistance. Note that you can contact them through chat or over the phone, but Phone wait times are longer than normal, so I recommend initiating a chat. Click here to get connected.
See you around.
