Charge 3 Heart rate too high and battery runs out fast
My Charge 3 like many others is reflecting my heart rate as too high. For the first few months I had it, it seemed normal. Then one day a few months ago it started to act "possessed" I saw others complain of this and updated the software. That "possession" eventually stopped however ever since then heart ratw records way too high in my opinion. Sitting on the couch doing nothing will show it as over 100 and up. Moderate exercise tends to show as 170. I compared to my charge 2. Charge 2 shows heart rates as lower as did my old chest heart rate monitor. I put on a blood pressure cuff which also measures heart rate. It and my charge 2 were in sync the charge 3 was much higher. I did this multiple times with the same result. Two nights ago I was a sleep for about 5 hours and woke up. My charge 3 did not record me as sleeping until after I went back to sleep again because it was recording my heart rate as high. How does this get fixed. I have seen many other posts about this marked as resolved and the issue was clearly not resolved as many people continue to complain about the same the same issue. I've updated software and rebooted. The battery on my charge 3 also runs out very very fast. It's supposed to have a longer battery life than the charge 2.it no longer does. I would like an actual fix.
1 REPLY 1
Thank you for visiting the Fitbit Community @TokunboG.
I'm sorry to hear that your Fitbit Charge 3 is not registering your heart rate accurately and the battery is draining quickly. Thank you for the information provided and for trying to resolve the issue before contacting us.
There are some factors that can affect the heart rate readings. Please make sure that you are following this guide to track heart rate with your Charge 3. In addition, you can find some tips to resolve heart rate issues on this article.
The estimated battery life for your Charge 3 is up to 7 days, but because battery life is affected by use and other settings, actual results may vary. To extend the battery life of your Tracker you can follow these recommendations.
Please let us know if you have any question.
