10-11-2018
04:54
15:06
10-11-2018
04:54
15:06
I’m having the same problem with my Charge 3. Everything else works. It is synced with app. Every morning alarm goes off. I tap the button. It resets the alarm. Nine minutes later—alarm goes off again. Even getting up and taking a sip of water and morning pill doesn’t stop it if I return to bed. Only thing that seems to work is actually waking up and getting my heart rate up a notch or two. I really only want the alarm go off once period. Like others I may just stop using it.
Moderator Edit: Updated Subject for Clarity
04-11-2019 08:08
04-11-2019 08:08
04-28-2019 02:48
04-28-2019 02:48
And 2 months since your post -- 6 months in total -- it is still not fixed. My Charge 3 just started doing this.
04-28-2019 08:02
04-28-2019 08:02
04-29-2019 19:13
04-29-2019 19:13
What button do you press to dismiss the silent alarm on charge 3? It doesn't work.
04-29-2019 19:18
04-29-2019 19:18
04-29-2019 20:46
04-29-2019 20:46
04-29-2019 21:44
04-29-2019 21:44
04-30-2019 06:58
04-30-2019 06:58
FIXED: After updating to Firmware version: 28.20001.60.39 on 2019-04-29 pressing the side button does cancel the silent alarm.
04-30-2019 08:29
04-30-2019 08:29
04-30-2019 16:56
04-30-2019 16:56
I have that update and it hasn't changed my silent alarm one bit! I still ger the snooze Alarm every time!
05-01-2019 00:47
05-01-2019 00:47
05-01-2019 07:44
05-01-2019 07:44
You have to press the invisible button on the left TWICE!
05-01-2019 08:59
05-01-2019 08:59
05-05-2019 21:49
05-05-2019 21:49
Pressing it twice actually works?
05-06-2019 03:14
05-07-2019 10:47
05-07-2019 10:47
Yeahhhhh! It works for me too.Thanks everybody for the long awaited solution!
05-14-2019 19:29
05-14-2019 19:29
It doesn't matter what I do - the alarm continues to snooze for close to an hour. When the alarm goes off, I've tried:
* pressing the button once - it snoozes, then goes off again (rinse & repeat)
* pressing the button twice - it snoozes, then goes off again (rinse & repeat)
* pressing the button three times - it snoozes, then goes off again (rinse & repeat)
* pressing the button MANY times in a row - it snoozes, then goes off again (rinse & repeat)
* pressing the button, then tapping the "Zzzz..." - it snoozes, then goes off again (rinse & repeat)
* pressing the button, swiping the "Zzzz..." - it snoozes, then goes off again (rinse & repeat)
* tapping the "Zzzz..." - it snoozes, then goes off again (rinse & repeat)
* swiping the "Zzzz..." - it snoozes, then goes off again (rinse & repeat)
* ignoring it entirely - it snoozes, then goes off again (rinse & repeat)
* putting it in a drawer - it snoozes, then goes off again (rinse & repeat)
* tapping the duck (or whatever the hell that thing is) - it snoozes, then goes off again (rinse & repeat)
* swiping the duck - it snoozes, then goes off again (rinse & repeat)
I've also updated the app with every new update, refreshed, unpaired, reset, etc and NOTHING works... Why can't we just STOP the alarm after the first notice?? The alarms feature USED to be useful. Now it's just a massive PAIN in the butt. The only option I've found it to turn off all alarms and use some iOS app that I found for my alarms. The problem is, I don't always have my phone with me.
Whatever you did in a recent update, broke this feature so that it's useless. When this thing stops working (and it will), I will NOT replace it.
05-14-2019 22:40
05-14-2019 22:40
Morning! You mention a button ... What button?? - my Charge 3 is new and I love it otherwise! The Alta silent alarm was turned off by tapping the screen lol .... Thanks in advance
05-15-2019 02:46
05-15-2019 02:46
05-15-2019 05:02
05-15-2019 05:02
