10-11-2018
04:54
15:06
10-11-2018
04:54
15:06
I’m having the same problem with my Charge 3. Everything else works. It is synced with app. Every morning alarm goes off. I tap the button. It resets the alarm. Nine minutes later—alarm goes off again. Even getting up and taking a sip of water and morning pill doesn’t stop it if I return to bed. Only thing that seems to work is actually waking up and getting my heart rate up a notch or two. I really only want the alarm go off once period. Like others I may just stop using it.
Moderator Edit: Updated Subject for Clarity
08-17-2019 08:47
08-17-2019 08:47
After pressing the button face alarm and notifications will show on the screen. Tap face alarm and that will make the alarm stop. I’ve done it twice and it’s worked. I just received my fitbit this week
08-20-2019 09:56
08-20-2019 09:56
doesn't work for me.
08-20-2019 10:01
08-20-2019 10:01
08-20-2019 10:10
08-20-2019 10:10
Press button on the side once, you see ducks, press it again, alarm stops. Make sure the button actually presses in and you're not touching the screen at the same time. I don't even look at it anymore, I just feel for the button and press it twice, not fast, not slow. If that's not working for you, maybe it's broken.
08-20-2019 10:22
08-20-2019 10:22
Nope. Doesn't work and I just got my replacement two days ago. I just turned off the alarms because it was so annoying.
08-24-2019 05:55
08-24-2019 05:55
I went to the manual and it states to dismiss the alarm, you must presses the side button TWICE.
08-24-2019
15:12
11:11
JuanJoFitbit
08-24-2019
15:12
11:11
JuanJoFitbit
Ok I found another way to shut off the alarm. When it goes off I have pushed the button at least 3 times. That has worked each time I’ve done it.
I found that out a few days ago. Works for me! Thanks for the info!!
Sent from my iPhone
Moderator edit: merged reply
08-24-2019 15:43 - last edited on 02-16-2020 18:11 by LiliyaFitbit
My pleasure
Sent from my iPhone
08-24-2019 16:08
08-24-2019 16:08
08-24-2019 17:17 - last edited on 02-16-2020 18:11 by LiliyaFitbit
Someone must think we are very stupid?
Sent from my iPhone
08-29-2019 23:20
08-29-2019 23:20
Even if I press the side button to stop the alarm it still goes into snooze mode. When I first had it, it didn’t do this it turned off. It is getting a bit annoying
08-30-2019 03:06 - last edited on 02-16-2020 18:12 by LiliyaFitbit
I push it twice and it shuts off. This is what the manual also states. Hope it helps?
Sent from my iPhone
09-09-2019 04:46
09-09-2019 04:46
I have never hit the ZZZ icon. I always press the button on the side and I immediately get up. It still goes off again in 9 minutes 75% of the time.
09-09-2019 04:48
09-09-2019 04:48
09-09-2019 04:50
09-09-2019 04:50
09-09-2019 05:15
09-09-2019 05:15
09-09-2019 06:20
09-09-2019 06:20
09-09-2019 06:56
09-09-2019 06:56
09-19-2019 05:35
09-19-2019 05:35
This is not actually the correct answer.
The User Manual for the Charge 3, in regards to the section "Dismiss or snooze an alarm," states that (emphasis are mine):
When an alarm goes off, the tracker vibrates.
To snooze the alarm for 9 minutes, tap the ZZZ icon or press the button. To dismiss
the alarm, press the button twice.
Pressing the button once on the side (based on the marked answers advice) will continue to present the problem the original poster asked about remedying. Instead, the button should be pressed twice.
09-19-2019 05:37 - last edited on 02-16-2020 18:12 by LiliyaFitbit
Yes I know. That is why I said to press the button quickly TWICE!!!!!
Sent from my iPhone
