10-11-2018
04:54
15:06
10-11-2018
04:54
15:06
I’m having the same problem with my Charge 3. Everything else works. It is synced with app. Every morning alarm goes off. I tap the button. It resets the alarm. Nine minutes later—alarm goes off again. Even getting up and taking a sip of water and morning pill doesn’t stop it if I return to bed. Only thing that seems to work is actually waking up and getting my heart rate up a notch or two. I really only want the alarm go off once period. Like others I may just stop using it.
Moderator Edit: Updated Subject for Clarity
09-19-2019 09:57
09-19-2019 09:57
09-19-2019 10:11
09-19-2019 10:11
It doesn’t work for me either anymore.
Best Answer09-19-2019 10:12
09-19-2019 10:12
Best Answer09-20-2019 05:22
09-20-2019 05:22
Tried that, I keep pushing the button instead of the Zzzzz. Keeps coming back every 10 minutes. Annoying. Even more annoying that you say you fixed it. Makes fitbit look 2x incompetent: once for the design flaw and twice for not knowing how to fix it. I’ll turn off the feature until you really fix it.
09-20-2019 05:25
09-20-2019 05:25
05:30
11:12
JuanJoFitbit
09-20-2019
05:30
11:12
JuanJoFitbit
Agreed. Pressing twice doesn’t work for me either.
Pressing twice (fast or slow) doesn’t work for me.
Sorry, I wasnt saying your answer wasn’t working, I was commenting generally to another post from fitbit saying the problem was solved. I didnt even see your post. Thanks.
Moderator edit: merged replies
09-20-2019 06:24
09-20-2019 06:24
Best Answer10-18-2019 08:36
10-18-2019 08:36
Hello
I've tried every which Way listed and it still doesn't stop. It is driving me and my friends crazy. I'm better off going back to the Samsung.
Cpb
Best Answer11-11-2019 14:03
11-11-2019 14:03
It doesn't work... pressing, sliding, holding... nothing can stop that thing buzzing
Best Answer11-11-2019 19:55
11-11-2019 19:55
11-18-2019 15:33
11-18-2019 15:33
So glad you finally got it to work!
11-18-2019 15:36
11-18-2019 15:36
Best Answer11-18-2019 15:48
11-18-2019 15:48
Best Answer12-27-2019 04:42
12-27-2019 04:42
Up vote this solution. Make sure to thumbs up. It is in consideration status. And is an easy and elegant solution to the button
01-07-2020 06:53
01-07-2020 06:53
When I press the button deliberately and make sure I don't touch the screen at all it's so snoozes the alarm and goes off again in 9 minutes
Best Answer01-07-2020 17:38
01-07-2020 17:38
Best Answer01-16-2020 09:30
01-16-2020 09:30
Thanks - will give this a go in the morning!
Best Answer01-16-2020 11:24
01-16-2020 11:24
I discovered you have to keep pressing the side button until the tim stays on solid. When I first started doing this it took 5 presses. As I persisted doing this it ha gone to just 1 press and occasionally 2 presses. But stick wit it and I think it will eventually work for you.
01-16-2020 12:51
01-16-2020 12:51
Mine does exactly the same thing. alarm goes off-I push the side button and it stops, 9 minutes later it goes off again and whether I push the side button or not it stops and does not go off again.
Best Answer01-16-2020 14:16
01-16-2020 14:16
