11-30-2018
07:12
14:34
11-30-2018
07:12
14:34
On my fitbit Charge 3, my silent alarms are going off. However, when I turn them off they automatically go on snooze and will go off in 9 minutes. Is there a way to turn the alarm off without putting it on snooze? Thank you!
12-03-2018 04:33
12-03-2018 04:33
Mmmmm that would be very annoying! Have you tried restarting the Charge 3 several tmes? Give it a go if you havent already. If that doesnt fix ot try wiping user data (settings app on the tracker and scroll down to About - you will need to set the Charge 3 up again afterwards). If that doesnt fix ot then contact Support (link in my signature)
Helen | Western Australia
11-30-2018 07:32
11-30-2018 07:32
What are you doing to turn the alarm off? If you press the button it shouldnt go to snooze, but I believe tapping does snooze it.
11-30-2018 09:28
11-30-2018 09:28
Welcome on board @teacher4, it's nice to see you here! When your silent alarm goes off, the tracker flashes and vibrates. To dismiss the alarm, press the button. To snooze the alarm for 9 minutes, tap the ZZZ icon. Tap snooze as many times as you like. Charge 3 automatically goes into snooze mode if
you ignore the alarm for more than 1 minute.
You can find more information at: How do I manage alarms on my Fitbit device?
Hope this helps, I'll be around if you need further assistance!
12-03-2018 03:19 - edited 12-03-2018 03:21
Thank you for your reply. I am only pressing the button on the side to turn the alarm off and I am doing it in less than a minute. However, it simply goes onto snooze mode. It is quite annoying as alarms continue to go off until I manually turn them off in the alarm section. Is there something else that I can do?
12-03-2018 04:33
12-03-2018 04:33
12-03-2018 16:27
12-03-2018 16:27
Thank you so much for your reply. I haven't tried restarting it yet, but I'm not sure I know how to do that. Sorry to have to ask, but how do you restart your fitbit tracker?
12-03-2018 23:45
12-03-2018 23:45
Woops, sorry! I forgot to put the link in on how to restart! Here it is
01-15-2019 03:22
01-15-2019 03:22
LOL.. That's so simple. Here I am going crazy tapping the screen every 9 minutes when all I had to do was push the button. Thank you!
01-15-2019 03:43
01-15-2019 03:43
haha so easy once you know.
01-18-2019 11:06
01-18-2019 11:06
Thank you. I didn't even know there was a button on the side of the charge 3. Good to know.
04-16-2019 23:31
05-27-2019 04:20
05-27-2019 04:20
Same thing here. Could only set the alarms from my computer; not charge 3 or phone app. Thrilled to have alarms, but can't shut off without it going to snooze. I don't want to do the reset. I really don't like this Fitbit.
06-17-2019 14:26
06-17-2019 14:26
The info below is on Page 26 of the PDF instructions for the Charge 3. Dismissing the alarm without putting it in snooze mode requires pressing the side button twice.
Dismiss or snooze an alarm
When an alarm goes off, the tracker vibrates.
To snooze the alarm for 9 minutes, tap the ZZZ icon or press the button. To dismiss
the alarm, press the button twice.
Snooze the alarm as many times as you want. Charge 3 automatically goes into
snooze mode if you ignore the alarm for more than 1 minute.
06-17-2019 17:44
06-17-2019 17:44
@MarreFitbit wrote:Welcome on board @teacher4, it's nice to see you here! When your silent alarm goes off, the tracker flashes and vibrates. To dismiss the alarm, press the button. To snooze the alarm for 9 minutes, tap the ZZZ icon. Tap snooze as many times as you like. Charge 3 automatically goes into snooze mode if
The last few days mine has gone to snooze. I have done nothing different than previously.
10-29-2019 04:59
10-29-2019 04:59
11-01-2019 06:40
11-01-2019 06:40
I instantly hit the button on the left side of my charge 3 when the alarm goes off. It still goes into snooze mode. I have restarted the charge 3, I have deleted and set up my alarms again, and insured my software is up-to-date but nothing works. I rely on my alarm twice a day to remind me to take my medication. it's important to me that it work properly and not be annoying, otherwise I may as well stuck with my Fitbit Flex and saved $100+. Do you have any other solution that is guaranteed and proven to resolve this?
11-01-2019 06:52
11-01-2019 06:52
Just press the button twice when the alarm goes off and it won’t go into snooze mode.
11-01-2019 08:55
11-01-2019 08:55
03-07-2020 06:49
03-07-2020 06:49
After your silent alarm goes off, to keep the snooze from coming on again on the Charge 3, push the side button TWICE.
07-01-2021 01:28
07-01-2021 01:28
It does not work like you describe for all of us. both methods snooze.
