10-20-2018
13:42
15:06
10-20-2018
13:42
15:06
I just recently got a new charge 3 but it is stuck on the "Fitbit.com/setup" screen and it won't show up when I try searching for it on my phone. I tried to restart it by plugging it into a computer, holding down the power button but it does not move away from the setup screen. Any and all help is welcomed.
-Thanks
*update* The tracker is completely unresponsive now.
10-20-2018 15:56
10-20-2018 15:56
I have the same issue. I just got it and it is my first fitbit. I may have to return it.
10-20-2018 17:06
10-20-2018 17:06
I spoke to the representative at Fitbit and he said I need to have the App set up on my iPhone 6s and then add the device and set it up. Otherwise, it won't work. For some reason, I could not get the App to work but once I turned on Bluetooth off and on and then went back to the App I was able to start adding the device.
Best Answer10-20-2018 17:29
10-20-2018 17:29
I spoke to the representative at Fitbit and he said I need to have the App set up on my iPhone 6s and then add the device and set it up. Otherwise, it won't work. For some reason, I could not get the App to work but once I turned on Bluetooth off and on and then went back to the App I was able to start adding the device. I also think what may have helped was that I had mobile tracking on my fitbit app from a few years ago and I removed this too. Not sure if it was the Bluetooth or this but I have a feeling it may have been the mobile tracking removal since I had tried to Bluetooth before and still had the screen.
Best Answer10-22-2018 20:33
10-22-2018 20:33
I am looking at the same option.
@amymontclair wrote:I have the same issue. I just got it and it is my first fitbit. I may have to return it.
Best Answer10-22-2018 20:34
10-22-2018 20:34
Thanks. Tried it all.
@amymontclair wrote:I spoke to the representative at Fitbit and he said I need to have the App set up on my iPhone 6s and then add the device and set it up. Otherwise, it won't work. For some reason, I could not get the App to work but once I turned on Bluetooth off and on and then went back to the App I was able to start adding the device.
Best Answer11-10-2018 13:08
11-10-2018 13:08
Did you sort this? I have the same problem
Best Answer01-25-2019 10:19
01-25-2019 10:19
I have the same issue, anyone solved it?
Best Answer02-04-2019 01:17
02-04-2019 01:17
I had the same issue, but then I download the fitbit app (android) and then following the step on it to pair it up with the device. now it is still downloading the update of the device.
Best Answer10-31-2019 09:33
10-31-2019 09:33
Mine is doing the same thing then stops says set up failed cannot see how much charge the battery has ! I have spoke to tech people did everything they said still new fitbit wont work this is my 3rd fitbit I'm done moving on to something that works👎👎👎👎
12-25-2019 06:04
12-25-2019 06:04
I have the same problem as well. The Charge 3 hasn't proven to be a very good tracker. Poor quality.
Best Answer01-16-2020 19:51
01-16-2020 19:51
Did u solve this issue , I'm having same problem and just want sort it
Best Answer01-17-2020 00:33
01-17-2020 00:33
Best Answer01-17-2020 06:09
01-17-2020 06:09
Best Answer01-17-2020 09:37
01-17-2020 09:37
Best Answer01-17-2020 11:31
01-17-2020 11:31
Best Answer01-24-2020 22:25
01-24-2020 22:25
I fixed my problem by removing my old fitbit from my Fitbit App, then turned my Bluetooth off, then turned my phone on and off and then just adding my new fitbit again to my App. The setup dissappeared for me and gave me a 4 number code to then enter into my Fitbit App.
Best Answer07-01-2020 07:27
07-01-2020 07:27
Fixed mine after I logged out from my Charge 2 account and registered a fresh account.
Hope this will work for everybody else too.
