04-25-2019
08:41
11:10
04-25-2019
08:41
11:10
Hi
I have just bought a FitBit Charge 3 SE and am trying to setup my Wallet
However When I try to add my Revolut card which you say you support for UK https://www.fitbit.com/fitbit-pay/banks.it fails.
Uh oh! Looks like we don't support this card for use with Fitpay. Tap below to see suppoerted banks and cards. If you feel this is an error, please contact the card issuer.
Is there any workaround for this?
05-02-2019 08:11
05-02-2019 08:11
Hi daro_brand
I had an email from the second line support on Tuesday saying
"We are still investigating this on our end. We apologize for for any inconvenience, but we hope to get you back on track as soon as possible."
05-02-2019
15:24
06:21
05-02-2019
15:24
06:21
@Coximus , if you have a physical card, and it didn’t work, please try deleting the card and then re-installing it and then try it again at a payment point.
I would recommend others tryng this as well. Sometimes, apparently, something can go wrong in the initial set up causing a valid card from a compatible bank account, to go wrong.
Deleting and re-installing would be a first troubleshooting step. That would seem to be the best advice if both Revolut and Fitbit agree that everything should be working.
05-02-2019 15:53 - edited 05-02-2019 15:54
The problem Julia is that there is nothing to delete/remove since the card cannot be added in the first place. The app does not store my Revolut card details.
Or maybe you suggest to remove the whole fitbit app and re install ?
05-03-2019
01:54
06:20
05-03-2019
01:54
06:20
Ah, @kalhimeo , thanks for clarifying! Apologies fir misunderstanding: I thought cards were being rejected when try8ng to pay — that’s the issue I had: I got the message “card not supported” .
Given what you said, I would suggest deleting the app and then re-installing it and once again trying to add your card. I guess it is possible that an older version of the app is not recognizing new banks added to the supported list.
If it works, that will help a lot of people, so let us know. If not, then I guess this is someth8ng that the bank and Fitbit will have to resolve between them.
05-04-2019 09:35 - edited 05-04-2019 12:41
Having the same issue with a new Revolut card in the U.K. Fitbit app (even after re-installation) won’t accept it, and Revolut say that while Fitbit say they support it, they don’t yet from their end. Bit of a Catch 22...
Maybe I need to use the card first to somehow validate it before Fitbit will accept it. Plus, I may have both GBP and EUR on my Revolut card at the same time - which currency will Fitbit use?
05-05-2019
14:43
06:20
05-05-2019
14:43
06:20
Hi everyone!
Thanks for all your reports with difficulty adding your Revolut credit cards to Fitbit Pay.
We've escalated this issue to our team so they can investigate what is the root cause of this problem.
We'll let you know in this thread what further information becomes available. Thanks for your patience while we look into this.
05-05-2019 15:50
05-05-2019 15:50
Glad I'm not the only one. I tried 2-3 times during the week with the usual "easy" tips of shutting down-up & reinstalling everything but it didn't work out. I believe there might be an issue with the connection between Revolut API and Fitbit. Let's wait and see they get back to us!
05-06-2019 00:33
05-06-2019 00:33
Still no success, unfortunately. Any clue? Any successful case you can point us to?
Thanks
A.
05-06-2019 02:33
05-06-2019 02:33
I'm Having the same issue. I still have a case open with 2nd line support, but not heard anything yet!
05-06-2019 04:40
05-06-2019 04:40
I am very frustrated with the same problem. When I tried to set up Fitbit pay I was dismayed to find hardly any UK banks were supported. So I opened a Revolut account especially as it was on the list! Then I found that didn’t work. I went to Fitbit help and was sent to revolut. Revolut help sent me back to Fitbit. Fitbit then escalated the case. I received this email confirming it had been escalated.
We're very sorry to hear about the issue you've experienced to add your card.
We're escalating this case and someone will be contacting you shortly.
Sincerely,
Christian and the Fitbit Team
That was last Sunday, 28th April and I have heard nothing at all since. I paid extra for my charge 3 to have Fitbit pay!!
05-06-2019
15:51
06:20
05-06-2019
15:51
06:20
@Alezante @Hitman_Botelle Hey, there! Rest assured, we've escalated this issue for investigation. We're really thankful for all your troubleshooting efforts and hope to have more information for you all soon.
@Picnichamper Welcome to the Fitbit Community forums! I'm so sorry to hear you've also experienced this issue with a Revolut credit card. Our team is going to look into this and hopefully, have a resolution for you all soon. I'll keep this thread updated so keep checking back in case we receive more information. Thanks for your patience!
05-07-2019 07:34
05-07-2019 07:34
Hi all,
I am trying with cards of my friends from Revolut and I found one card that I was able to add to fitbit. His card has the new MasterCard logo whereas mine has the old one.
Can you help me with this to try to find a correlation -- what year is your expiration date and when you look on the back of the card who is the issuer (small text at the bottom). For me the issuer is Paysafe and year is 2020, whereas my friend has different issuer.
05-07-2019 08:17
05-07-2019 08:17
Hi @daro_band
No issuer on mine (Although it might be TAG Systems), expiry is 2024
05-08-2019 06:52 - edited 05-08-2019 06:54
This problem was mentioned in other topics as well and somebody responded with this info from Revolut:
"I had the same issue (UK), and spoke to Revolut, who said that it is currently being tested with Fitbit Pay and only some cards are available. They’re hoping it will be rolled out soon, but have no timeframe. The Fitbit website listing Revolut as supported is very misleading!"
It is nearly 3 weeks old so hopefully Revolut will launch full support for Fitbit soon
05-08-2019 07:11
05-08-2019 07:11
Yes it is very misleading and I am not at all happy. Apart from not being able to use it I have wasted so much time on it!
05-08-2019 08:04
05-08-2019 08:04
05-08-2019 08:07
05-08-2019 08:07
05-08-2019 12:39
05-08-2019 12:39
Same doesn’t work for me, worked for boon.
but boon want to charge every month,
Os there a kick back too them probably !!!!!
It is massively frustrating especially a company the size of Fitbit,
not to get right first time and the cost’s in our time and money.
Also not to get UK banks involved ???
But you wonder why Apple charge to much
IT WORKS !!!!
I will give a month, if Fitbit don’t fix the issue.
I will put on eBay and buy an Apple iWatch,
at least I know it will work !
05-08-2019 12:54
05-08-2019 12:54
If you want anything to happen quickly
put your complaints on there social media platform
eg Facebook and others they might have
as there are millions of people looking !!
05-09-2019 11:03
05-09-2019 11:03
Not sure if its related but most of the Revolut cards I’ve seen in the UK are Visa not Mastercard, perhaps this is where the issue lies for many like me.
However Revolut virtual cards display the Mastercard logo so in principle should work?
