10-06-2018
13:07
15:47
10-06-2018
13:07
15:47
When I swipe over to Weather on my Charge 3, it never works and says to try syncing with my phone... That doesn't work either. Any insights?
12-20-2018 19:55
12-20-2018 19:55
12-21-2018 12:31
12-21-2018 12:31
Dear Moderators:
Can you please post FitBit's returns and reimbursement mailing address? I would like to return my Charge 3. My weather issue still isn't solved, it no longer connects to my phone's bluetooth, and as of two days ago the screen no longer works at all. Note: I require FitBit's mailing address as I bought my Charge 3 in an airport store, and cannot simply go back to it.
Thanks,
Damien
12-21-2018 13:23
12-21-2018 13:23
@DamienLee You'll likely need to contact customer service.
12-21-2018 13:25
12-21-2018 13:25
@astoker wrote:Looks like the latest firmware update is addressing this weather issue. Can’t wait for it to be available to me so I can test it out!
The newest update fixed my weather issues. Very happy!
12-21-2018 14:55
12-21-2018 14:55
12-21-2018 19:41
12-21-2018 19:41
No, the latest firmware did NOT fix the weather problem. Ugh!
It irritates the f@ck out of me! 😠😡🤬
12-21-2018 20:15
12-21-2018 20:15
I’ve never even seen the option to update my C3 tracker. They keep saying it is updated but it still doesn’t work right.
12-24-2018
03:21
08:26
12-24-2018
03:21
08:26
Hey guys, I hope you are doing fine.
Thanks all for the feedback and update about this, it's great to know that for some of you this issue has been resolved. For the ones that keep having it, keep in mind that this problem has been escalated to out team. Once we have some news about it, we will be than glad to share them with you.
Also, if you are unsatisfied with your purchase from Fitbit.com for any reason, you have 45 days from the date of shipment to request a full refund. For more information, you can check our warranty policy.
See you around.
12-24-2018 08:41
12-24-2018 08:41
I am pleased to report that the issue with the weather app not automatically syncing with the Charge 3, thankfully, now seems to be resolved for me and fully working following the latest recent software update. Thank you Fitbit.
Sorry to hear that for others, this issue has not yet been resolved. Hopefully, it will be soon.
12-24-2018 11:17
12-24-2018 11:17
My Fitbit Charge3 is on V20001.49.45. Is there a newer version?
12-24-2018 11:59
12-24-2018 11:59
12-27-2018 05:41
12-27-2018 05:41
I followed the steps for the Weather App and still couldn't figure out how to view the weather from my Charge 3. This did the trick! Thanks!
12-28-2018 08:52
12-28-2018 08:52
Thank you for the instructions. I was able to get the weather added to my Charge3.
12-31-2018
03:40
08:22
12-31-2018
03:40
08:22
Hello all, I hope you are doing well.
It's great to see here that this issue has been resolved for many of you. For the ones that keep having this problem, as recommended, check if your Charge 3 is updated.
Keep me posted.
12-31-2018 05:35
12-31-2018 05:35
12-31-2018 10:51 - edited 06-09-2025 08:22
I'm so glad to hear your Charge 3 has been working better after performing the firmware update @Haveeby!
While reading your post I was wondering if you're using an iOS device? If so, changes done on the Fitbit app on my iPhone were not being synced with the Charger 3. So, I tried General>Reset>Reset Location & Privacy on my iPhone, and then everything started working. So, it's fixed and I can start seeing the Weather on my 'Location'.
Hope that helps your Charge 3 to display the Local weather!
12-31-2018 12:07
12-31-2018 12:07
12-31-2018 12:30 - edited 06-09-2025 08:22
Sure, not a problem @Haveeby. Do it when you get home! And don't forget to keep me posted.
Hope you have an awesome Happy New Year!
01-01-2019 18:05
01-01-2019 18:05
I have an iPhone 6 and reset the Location and Privacy settings as described and the Weather app is currently working.
Thanks,
01-02-2019 09:16 - last edited on 02-07-2020 15:35 by LiliyaFitbit
Best answer out there, for finding the weather app on the Charge 3. Made my day!!!
Moderator edit: format
